Team Losi JRXS
#2222
My experance has been a few parts make it to the shelf before the car does....But i know this does not always happen
#2223
Originally posted by vtl1180ny
Todd... Will it take a stick pack with tamiya connectors??? We're all concerned how we're going to solder or get out deans/corally or lightspeed connectors in there....
#2224
Will it be possible to put a 48DP spur on? By that I mean does the spur gear screw onto an adaptor, or does it have the pulley moulded on ala XXXS? Its just I have hundreds of 48DP pinions and don't wanna have to replace them all with 64's just to run this car
Oli
Oli
#2225
Oli
Oli
#2227
Pookyt-The only part # I know of is the skoda 2. It is LOSA8063. They were finalizing all part numbers late this past week to get the manuals done.
vtl1180ny-I have not tried it yet. I will and let you know.
Randy-If you are speaking of the Team Trinity blue collars for the Losi...they will not fit. The others have been using Tamiya collars. However I think once you get the kit you will not want to change the collars. They have the o-ring already in the collar and are hard anodized.
BiggerBrother-I believe Precision Racing Systems is making a spur gear adapter for the car. So you will be able to use your 48 pitch.
Nvisible-Not yet....sorry
#2228
Will we be able to get the Skoda2 before the car comes out or do we have to wait after the car comes out? Will the car come with the aluminum hing pin blocks that u used for the Worlds or will they be the other ones?
Cant wait till it comes out. Its gonna be a great car.
#2229
I am pretty sure that the car will be coming with composite plastic hinge pin mounts, the Al. should be an option though. And prolly around the same time for the Skoda too.
#2230
Well its good that the composite ones are going to be included. Cause then the car will be lighter. All you who race in a club that doesnt check weight youll have a big advantage. lol
thxs
thxs
#2231
but they are easier to break than the aluminum ones
#2232
how often do u break hing pin blocks. I sure dont on my XXX-S and i have the plastic ones not the graphite ones. It wont matter if people cant keep up with you. lol You most likely will break an a-arm, or a hub.
#2234
hmmm...that should not break easy. That part does not take enough stress to break, unless your using coat hanger wire for a sway bar. plus that should be a graphite part.
