Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#541
Cody, from what matt told me, he was basically running the setup me and Karl had at the gate for 17.5. Id be happy to post that up for ya
#543
Mike, I would not say that I was running "basically the same set-up" as what you guys ran.
Our set-ups might be close, but it is the small details that make a difference. For what it's worth, my set-up never varies much on asphalt to carpet. Just heavier oil and less toe. This time, I also went up in springs to 16.5 Front, 15.5 rear. I play around with ackerman settings constantly and run different diff heights than at least what Matt and Karl do.
#544
BTW, the belt tensioner/battery stop looks awesome. Very slick.
#545
Doh! Of course.
Well, Matt ran his usual set-up but went to the shorter front link and then shortened his wheel base. He was running less droop and softer springs than what we did. I believe he also went up in shock oil.
Sam, who finished second was running essentially the same as what I was. We ran more droop and stiffer springs than Matt. Our cars had a little more body roll which suits our driving style better. Matt's car was very flat and slid around the track ours rolled more and carved through the corners. Both were about equally fast, it was just a matter of steering the car with the front end like we like or if you like to slide it like Matt did.
#546
For mod motors, the LRP X12 4.0 is the absolute smoothest motor I have ever used (even compared to higher turns). Even on somewhat tighter carpet layouts it is very manageable, like a good 17.5...... try one out if you haven't yet
I remember the core of the setup, but feel free to share it for others to see! Just got a great medium-bite setup from my friend that he used Saturday to great results, also, so looks like I'll have plenty of things to try out this week!
Seems like the long link is used 99% of the time up front on TC6's...... I plan on trying a shorter link for awhile. It seemed somewhat aggressive on my T3 and I loved how much steering that car always had, especially on high-bite.
#548
This is what im on after last saturday, has a couple tweaks from when we were at the Gate, and it feels even better than when I was up there.
#549
I tried the long link in the front and the car was un-driveable. It made it hard to drive tight lines. It's almost like it makes the front feel wider than the rear end and it starts to make the car feel like it squares the corners off oddly. In my opinion it makes the car feel like the front and rear are disconnected. When I have run long links, I run the front and rear. I like the balance achieved from the same length links I guess.
Thanks for the words Frank. We all did well this weekend. It was fun to see all you guys running RSD parts going around the track fast. That's the best part of it all.
#550
Yes, the long link is used most of the time because it makes the car mellower. But the fact is that ALL FAST TC's use a shorter link than the TC6 in the front. ALL OF THEM. There is a reason why they do this. It makes for a faster transitioning car, which in turn means a faster car around the track.
For short front links, are you keeping the link parallel or doing an aggressive angle like typically used in the rear? I'm guessing between ackerman and caster settings you wouldn't need as much camber change via the link as you would in the rear.......
#551
I run short links for mod and stock, asphalt or carpet. Whatever class, it does not matter. I also run my links with very little angle front and rear. Look at the top pro's cars and they seem to do the same. Volker, Rheinhard, Jilles, etc. all run shorter links than the TC6 has in the front and they also run very little angle on their links F/R.
#552
Had a blast this weekend @ the Fall Classic. Once again, I am very pleased with the RSD springs/pistons/bladders. Cristian showed me the new parts that are in the works, and they look sweet! I especially like the rear-end body brace/bumper thingy...
Ended up qualifying 5th in 17.5 sedan. Had some poor luck in the 1st and 3rd A-mains and ended up finishing 6th. I think I am starting to shake the rust off and get back in my groove....
Car was working quite well though, handling better than it ever has on carpet.
#553
this is a video of Sam Hand winning A3 with all of the RSD parts, sorry CT i would have recorded your but my phone died after i recorded this.http://www.youtube.com/watch?v=s4bB7jowNOc
#554
RSD = FAST
Thanks Frank for the vid, awesome. I'll have to figure out how to burn that to a DVD.
FYI I also ran 0 degree rear hubs with less toe than asphalt on the carpet. Thicker gear diff oil too.
For me the dope time and method was also impactful as the track gripped up through the weekend.
I'd like to try even shorter links (AE #3 or 4 or inside rear hub holes) with slightly less static camber at all four corners just to see how the car reacts to it.
#555
Hello Cris,
how are the DCJs progressing?
Thanks, Lojz
Thanks, Lojz
