Barracuda from Alex racing >
Like Tree1Likes
Old 03-27-2003, 05:35 PM
  #1546
SpeedTech's Avatar
Hermi,
Try putting the spur gear on the other side like so:
http://www.alexracingusa.com/images/Floating1.JPG
http://www.alexracingusa.com/images/Input2.JPG
after I did that, I get full contact with my pinion gear. When the PAL motor mount comes, I will have to see how the alignment is. If anything, we carry long shank pinion gears.
Steve Wang
SpeedTech is offline
Old 03-27-2003, 05:38 PM
  #1547
Herminator's Avatar
Originally posted by SpeedTech
Hermi,
Steve Wang
Thats what I've done now, and what I was trying to tell Dave, might give the screw clearance problem. I don't want to have to buy a load of new pinions, when the parcel you sent arrives I'll have 19-32 tooth pinions all covered, mostly titanium ones too
Herminator is offline
Old 03-27-2003, 05:54 PM
  #1548
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Gotcha'
what spur size are you guys using now for the R2..?? I would think that 72~74 would be the best
-Dave
JDM_DOHC_SiR is offline
Old 03-27-2003, 06:17 PM
  #1549
Herminator's Avatar
I used 72 on Monday, the kit spur, and with my GM3 I ended up with a 23 tooth pinion, the motor got a little hotter than I would normaly run but boy was the car fast
Now I have a 74 spur in, since the 72 has more like 70 teeth and half of those left are kind half teeth too I'll probably use 74/23 from now on with my GM3 indoors, possibly 72/22 aswell, when my parcel from Steve arrives with the 22 and 21 tooth titanium pinions
Old 03-27-2003, 07:17 PM
  #1550
anyone know the largest 64 pitch spur gear i can run on the new R2 without it rubbing on anything of course?
RideRed98 is offline
Old 03-27-2003, 07:27 PM
  #1551
Its so funny to see you guys that use 27T motors run such Big spurs and small pinions.... with the 23T stockers that I run ...I run 69T Spurs and 30~32T pinions with ratio's from 6.0~5.2
-Dave
Old 03-27-2003, 07:34 PM
  #1552
Talking
I belive a 110~114T would be the bigest that I would want to try....But you might not want to run 64P without the PAL shaft holder....you might eat one up really fast! I would wait untill Steve gets the new PAL Shaft Holder/Motor mount it and then Run 64P
-Dave
Old 03-27-2003, 10:01 PM
  #1553
fai
Regional Moderator
fai's Avatar
-Dave
JDM: Hmmm.... should 101T be the largest acceptable 64-pitch spur gear? As 101T nearly goes out of the chasis! 110-114T will scratch the ground already!
fai is offline
Old 03-28-2003, 07:04 AM
  #1554
Herminator's Avatar
Looks like the new RC Lab 7-7 pro comes with blue posts for the battery straps should go very nicely on my cuda may have to order four though :/
Old 03-28-2003, 08:14 AM
  #1555
Yep ... but he did ask what is the biggest that could fit in there
-Dave
Old 03-28-2003, 10:36 AM
  #1556
Do ya' have a pick of what they look like ..??
-Dave
also a part # would be nice too
Old 03-28-2003, 10:39 AM
  #1557
Yeah Herm, part # would be nice.
elnitro is offline
Old 03-28-2003, 09:23 PM
  #1558
pkranger63's Avatar
Okay just about got the car ready to go. The problem I am having is the turnbuckles for the front and the rear camber links hit the shock caps ever so slightly. It almost seems as though the shocks should be mounted on opposite side of what the pictures in the instructions show. That or I did somthing wrong but for the life of me I can't seem to figure it out. Any ideas?
Matt
pkranger63 is offline
Old 03-28-2003, 09:25 PM
  #1559
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Missing something
Sounds like you missed the aluminum shock tower spacers ?
RedBullFiXX is offline
Old 03-28-2003, 09:30 PM
  #1560
pkranger63's Avatar
Got the spacer in there, looking back at the posts and pictures of the R2 it looks like the turnbuckles are right next to the shock caps maybe even touching..On the R1 it looks like the shocks are mounted on opposite side of the shock tower with no chance of interfernce...Hmmm
