Team Associated TC4
The wheel load at each tire will change when you turn the wheels. The easiest way to see it is to put your car on the scales, turn it on, turn the wheels. The scale readings will change due to the caster effect. It will move weight from one diagonal to the other on the car.
In full scale racing, we'd use steering rack blocks to lock the steering in place when scaling the car and setting the cross weights. Otherwise you'll chase your tail when trying to adjust them, if the steering moves.
Mark
Mark
I would have never of thunk it. I just put the car on a level surface, make sure the front wheels are pointing straight ahead, bounce the suspension a few times and check my settings. The built in resistance at the servo is enough to keep the wheels straight and bouncing the suspension should leave it in a neutral position. Besides, I would just find a way to bump the radio any way and away she goes.
Will find out Sat if it helped me any!!!!!
Any tc4's in the TC videos ???
All in Florida.
TC
The XXX-S (orange)
The TC4 (white front, blue rear)
VTA
XXX-S Mustang / Cuda (Orange)
TC4 Dodge Challenger (white front, blue rear)
Jato
GT2 (white front, blue rear)
GT2-E (white front, blue rear)
SC/Autocross
SC10GT-E (white front, blue rear)
TC
The XXX-S (orange)
VTA
Jato
SC/Autocross
Ok... thanks tmail.... Time to scrutinize the videos....
Wow.... The tc4 in the videos is on ice... No traction at all... I had the same problem with my car on asphalt(FBF) when I used the AE shocks with two hole pistons and thick oil(80wt) or 40wt... I guess putting more holes in the pistons will reduce pack, and increase traction, but without the BERT mods, it will be impossible to catch the other cars over there......
Wow. Just wow...
Wow to the Mods..... Thank you very much....
Is there some way to stop these nonsense posts on this thread? I don't just mean using the ignore button, but stopping the spreading of these false improvements that others might take seriously...
I wish. Oh how I wish.
Empirical facts mean nothing to him. He's the expert in everything and actual racer of nothing. He has no sources for his information.
It's really amazing.
