Team Associated TC4
When I put a Lipo in it becomes tweaked badly. I have tried a couple of different battery mounts; Velcro strap, tape and the AE posts. It appears the top deck and the LiPo case interfere with each other. I tried to make a new LiPo mount, but still had issues with the top deck.
If your lipo is hitting the top plate then its way to big and probably not legal for racing.
A FTTC4 chassis & top plate weigh around 105g, how much does your DC4 chassis and top plate weigh ?? Everything else is the same, so curious on how much lighter the DC4 chassis is to claim the car will be MUCH lighter.
The dc4 le chassis does not use the four aluminum diff case spacers and also uses left carbon fiber on both decks and no Center spline... That's a good 120grams Off in my book...
I meant less (not left) CF on both decks.....sorry....
Aluminum camber link mounts ?? all 4 weigh 14g, DC4 requires you to cut down the plastic ones which weigh 8g ... a weight savings of 6g !!!
The Center Spline on the TC4 is optional as are the top deck standoffs, you dont need to use them if you want more flex, shocked that u didnt know that.
Your book must be from a different planet, lol
If your going to post numbers ... post real numbers and not something from you book.
3,194 posts and u still dont know what the edit button is for
Southern Oval Champs at Minnreg - August 24/25th - VTA !!! on the OVAL
Don't be mad because you failed to win that Bmain brother. If you had a dc4 le then , you would have won.... By the way, the dc4 le gives you the opportunity to use the shocktower instead of the plastic pieces that you said had to be cutoff...
The dc4 le total weight has been posted, and there is no way your Car(not an original tc4) will ever get close to it in my BOOK !!! Try to do better at the next iic , and then pass 1000 posts, before talking here....lol... Why aren't you running 17.5 anyway ??? Afraid to step up or is your so called tc4 too heavy ???
We need all the tc4 owners to post the weight of their cars to see if they can come close to 1050grams without a battery pack...... Good luck ....
My lightest FTtc4 weighs 1212grams (no battery), maybe 1172grams with light electronics....
HOW MUCH DOES YOUR TC4 WEIGH ?????
Dude. Seriously. Stop embarrassing yourself.
2. im not your brother
3. yeah im sure a dc4 would have easily won, it drives itself right ?? LOL
4. you can run tc3 shock towers on your tc4 ... but why would you.
5. like I said, your book is from a different planet.
6. always try to do your best
7. its not about quantity, its the quality
8. who said I dont run 17.5 ?
9. it weighs 1550g ... so its legal for vta, 1450g for my GT, 1380g for my 17.5
Said it before ... troll.
Awesome racing at snowbirds Rojna
Win next time ! Post your tc4 weight without the battery pack !!!!
If I was there, I would have won, brother !!! Don't put down the Dc4 le Ok !!!
What the hell happened to this thread?
Hey DesertRat, how is your DC4 comming along, do you run it in 17.5
