Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 01-18-2005, 08:01 PM
  #2761
Default Re: Foam setup
Originally posted by Greg Amendola
This setup is for people using the plastic is fantastic chassis and parts. It hasn't been tested on graphite, but I suspect the results would be very close.
NOTE: The rear shock uses the outside top and bottom mount locations. I've also gone to the silver (middle thickness) swaybar in the front.
https://home.comcast.net/~travissurr...20Amendola.pdf
Car has been very easy to drive and very quick in and out of the corners.
Good luck,
Greg
I ran close to this setup except one shorter camber link front and rear. and white springs in the front. I tried purples, seemed like the car pushed with them. The only other thing i can tell is im runnin 6*caster blocks with no shims under the arm mounts...are you running anti-dive though? How does your car steer? I like to have my car turn when I want and not have to wait on it but still feel planted and smooth...lol
runnin rc10 is offline
Old 01-19-2005, 06:29 AM
  #2762
RCknight's Avatar
Default Froboy....
are you racing in Omaha? Wed. or Sun.?
RCknight is offline
Old 01-19-2005, 07:31 AM
  #2763
raving-monkey's Avatar
i've read a lot on shimming the steering to get rid of some of the slop (im getting some rpm ball cups this weekend to reduce it even further) but i was wonering what shims i actually need (like what kind of size) and where i actually pit them, on the part where the bearings are..or on the bushing part things near where the balls are for the steering links?
raving-monkey is offline
Old 01-19-2005, 08:48 AM
  #2764
Trader Rating: 18 (100%+)
should i have a front sway bar for a small tight turn track?
Roberto Falcon is offline
Old 01-19-2005, 08:51 AM
  #2765
i wouldnt use any rollbar for a small track...imo you would get to much understeer...as iirc aren't roll bars designed for lage and flowing tracks?
Old 01-19-2005, 09:05 AM
  #2766
If you sand down the height slightly on the standoffs (part #'s 2229 and 31022) on the small ends, you wont have to shim the steering at all. It got rid of all my play in the steering rack - now all that is left is in the ball cups.
Corner Weight is offline
Old 01-19-2005, 09:16 AM
  #2767
Has anyone seen a picture of the chasssis mod to get rid of the battery strap?
DOTMAN is offline
Old 01-19-2005, 09:20 AM
  #2768
Boomer's Avatar
couple of pages back.
Boomer is offline
  #2769
If you wish to use shims in the steering rack, axle shims work fine, put them between the hex shaft thing and the bearing.
For the hex screws use motor shims, or, I used input shaft shims.
MartynD is offline
Old 01-19-2005, 09:37 AM
  #2770
Travis S's Avatar
Trader Rating: 46 (100%+)
Did you shim the top and the bottom or just the bottom?
Travis S is offline
Old 01-19-2005, 10:25 AM
  #2771
At the top, under the screw/hex head
MartynD is offline
Old 01-19-2005, 11:08 AM
  #2772
sweet, i just filed down the bushing part things a bit, might of done it a tad to far because when they were fully tightened it binded a bit...but backed it off a tiny bit and thread locked it..and it works a treat, getting rpm ball cups should get rid of the rest of the slop.
thanks guys
Old 01-19-2005, 11:33 AM
  #2773
howard hudson's Avatar
dude your pic looks like that dude from MONSTER NATION !!!!!
howard hudson is offline
Old 01-19-2005, 12:44 PM
  #2774
Boomer's Avatar
thanks guys
That's actually where I shimmed things. I filed down just a bit too far, then used motor shims to space it out so it was PERFECT and then locktited things.
Boomer is offline
Old 01-19-2005, 01:48 PM
  #2775
CRASH's Avatar
Trader Rating: 26 (100%+)
Default RPM Ballcups
Carefull when using RPM ballcups. I got some and tried to do the same thing and it bound up the suspension pretty good. Even after breaking them in a bit they were still pretty tight. So I went back to the Associated ones.
As far as slop goes I got my carbon fiber kit last week and that pretty much removed any and all slop from everywhere but the steering rack. I am going to dremel the stand offs a little as described earlier to eliminate this problem.
Later,
CRASH is offline
