Team Associated TC4
#2011
Craig Drecher just stuck one in 3rd at the Asian Reedy Race aswell. Not a bad result!
#2012
Hello dudes is it someone that have a good start setup for carpet tracks? would like to get that if it is possible!
#2013
What sort of tyres?
#2014
sorex and schmacher white belted
#2015
sorry sorex 28r
#2016
We don't have any with those tyres specifically but we have a few carpet setups on our site
http://www.cmldistribution.co.uk/car_setup.php
#2017
Witsh tyres do you use in uk?
#2018
On the site we have setups for CS27, Foams, Schumacher Rally Blocks/Mini Pins and a few others.
#2019
There are 2 TC4s at are track. They are starting to stay at the top. Especially one. He is basically taking it to BMI Xrays and PRO4s as well as the XXX-S.
The car is going to be as good if not better then the TC3 but it is going to take awhile for people to trust AE when they do such a good job of denying and covering up all the problems. Would be best I agree to just say we have a problem we are fixing it.
Later,
Later,
#2020
Hi guys, i finally gave in and i;m now getting a TC4.
I'm just putting in an order for a new servo, spool etc but i noticed even some of the team drivers are using alu pivot block things (where the hinge pin goes in).
i;m just wondering if its a worthy hopup, which one do i get and how many (one for rear? or a set for each end of the car?)
what are the most important hopups needed for the TC4, ive got the graphite kit in mind but im just waiting for them to get them in stock (so it will be ordered when it comes in stock)
#2021
I'm running my TC4 as standard kit spec and its going very well.
#2022
Originally posted by Jack Smash
Rumor has it that AE has fixed the problem with the molds and new arms will not have this problem.
Info like this should be posted on the AE Website. Sad that TPhalen has a nicer, more relevant site than AE does. Good work Tony.
At our local track too I'm starting to see a shift. Or Wednesday night race had only one belt car and that was an RDX. The others There were 2 TC3's, one pro4, and 2 TC4's.
I think people are starting to figure the car out a bit. I know mine gets better with every run...every change.
Blake
#2024
The mold on the arms are fixed. AE listened to the racers/customers in the early stages of the kits release and fixed the weak point. The mold has been corrected and you should see a 30% increase in arm strength.
