Ko Propo VFS-1 ESC
#1006
Carpet profile?
Our VFS-1 (new version) arrived yesterday. Anyone got any suggestions or examples of a profile good on carpet?
#1007
Originally Posted by Bartwubben
Here is a sheme of the koPropo vfs-1.. there are 2 ways to by-pass the terminal overload protection.. One is verry simple, you just cut the little wire in the 2 boards. the other is more difficult.. you have to remove the little ciruit chip en then fill it with solder thin..
Good Luck,
Bart
Good Luck,
Bart
Can anybody translate this please????????????????
#1008
#1009
Matt, I could figure it out, i just didn't want to miss anything thanks.
#1010
I just picked up a VFS-1 and noticed that there is no wire for running a 7.2volt servo (KO PDS-2123FET). Can I connect the power lead on the servo to the positive terminal on the speed controller to get it to work? Thanks in advance.
Eric
Eric
#1011
Pretty sure you can but you need a choke thingy.
#1013
VFS-1 PROBLEM ..... SMOKE
Guys ... NEED YOUR HELP,
Just bought the VFS-1, has had one race meeting without any problems. It was awsome.
Last night connected it up to the battery with no probelm. When I went to unplug it smoke started coming out of the negative motor wire (at the esc). Did not even run the car !!
Now every time I swith the VFS-1 smoke comes off negative motor terminal . The strange thing is that the esc still works, also works properly in communication mode.
Ther does't appear to be any short between the esc terminals (checked for strands of wire etc).
Any ideas guys ? Can't work it out .... very frustrating
#1014
Originally Posted by Hebiki
danjoy... havent forgotten about you. ill send you a PM sometime this weekend.
#1015
hi ko staff and everyone,
When i connect the vfs1 to the batterys....there was spark! this happens even though everytime i have made sure that the vfs1 has been switched OFF....is my vfs1 having problem?
thx
thx
#1016
thx
thx
#1018
thx
thx
#1019
Thx All ^_^!
#1020
