Serpent S411
#1306
There are many differances in the new batch of kits. The chassis is different to the standard one (narrower again, 2.25mm) and car has medium plastics throughout. There are a few other small bits and pieces also, the driveshafts have serpent 46mm etched into them now. Really like this car, but never have I had so many issues building a car with faulty parts!
I had a few shock balls and arm balls that needed to be replaced as the pin would not go through. This was annoying but an easy replacement. my other 2 issues on the other hand
My kit has come with 1 different size shock body (obviously from a 1/8) so i cant put any shocks on the car and will have to buy a replacement, another delay. The other issue I have is that the rear of the car has a big bind in the drivetrain. Tried different belts, essentric's, whole diff and bearing and it still exists. The belt has a bigh/low spot no matter what i try, the essentric's are visibly wobbling in the bulkheads as the drivetrain rotates. Im going to try and fit a prototype chassis that has been sent to me and see if that fixes the issue, but im not liking my chances.
Hope Serpent get the rest of the kits right as there are way too many things wrong with mine. Not the best first impression thats for sure!
#1307
Every car that is on the podium at the big events have a lot in common these days as it is proven to be fast. What the cara I mentiined earler don't have is suspension arms mounted directly into the lower deck with alloy blocks. Xray is 1/2 way there and along with the high quality of the kit it makes for a good chassis. But kits that do everything properly are the ones at the front of the field.
#1311
V1 , V2
Some re-sellers might change the kit specs to accommodate racers needs and local track conditions or as a selling tool. Out of the 12+ kits sold and 3+ kits built apart from a wonky diff case which was replaced i have not encountered any other issues with the kits received and sold.
Cheers
Ren
#1312
Funny you should mention that... Have been thinking about it quite a lot after finding my way with some serious speed at FEMCA. I had a ph call today that will likely pave the way for a good trip so as it stands it is about 50/50. If I get what I want out of the chassis/power plant next weekend it will be very very likely.
#1314
Looking at the info i have in front of me and other sources the only kits available still have the 2.5mm chassis and some minor improvements in molding and a spur included. I still have to see a kit supplied with a 2.25mm chassis. Considering that the turn over from the importer is quite high and new kits arrive every 4 weeks to fill demand !!!
Cheers
Ren
Cheers
Ren
#1316
Hi,
Thinking about getting an S411 just sold my T3'11 and was going to get the new Xray. I do like the Serpent espcially the shocks and the gear diff but worried about quality of parts and fitment after having Xray and slop in the steering. So convince me why I should get this and not wait for the Xray
Does it need the lipo holders or is just tape ok ?
Is there anything extra that's worth changing that doesn't come with the kit ?
What size spur's fit and what size comes with kit ?
Thanks.
Thanks.
#1317
kit comes with a 84t 48p spur
using battery tape only will be fine
you may want to pick up the normal tuning items like different springs and anti roll bars.
fitment of everything on my s411 was great. i didn't have to rework any parts. i did have to use 0.010" thicker washers on my steering bellcrank than what is supplied with the kit.
all in all it was a great build.
go ahead and get the s411, you wont be sorry!
#1318
I was thinking about waiting for the Xray too, but couldn't wait and got the s411.
In my opinion Serpents quality fit and finish is on par with Xray and is better then Associated.(I've had all 3 brands)
I would get the battery holder as tape can break in a big crash. As far as spurs go 84 is the biggest 48 pitch you can fit (Xray spurs fit great) and not sure about 64 pitch.
Also- parts for the Serpent are cheaper then Xray, it has more steering then a T3, plus the gun metal grey anodizing is sexy!! Just get one...
#1319
Just Finished building my new S411 Great fit and finish and a fast build, Loved that Titanium grey finish and the slop is very very minimal in the steering rack, it's just littel vertical slop, but nothing sideways that i could notice witch is acceptable in my eyes but now it's just waiting for tomorrow and enjoy my car and figure out a setup habby racing everyone
#1320
Changed my mind
