Like Tree16Likes
Serpent S411
Old 03-18-2014, 04:10 AM
  #6391
mazmo's Avatar
Originally Posted by RavensNightFury
so that would work on both am I right
sorry. that is for 13.5 blinky (no timing).
for 17.5 would you run blinky or boosted?
mazmo is offline
Old 03-18-2014, 06:32 PM
  #6392
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Hi all, i'm busy building my first ever Serpent kit the S411 FF that I plan to run in 21 Blinky here in Sydney, so far i'm really impressed by the kit the build quality is impeccable (having owned Tamiyas my whole life i was still impressed). One thing I am finding on my turn buckles is the rod ends fit very snug onto the ball studs, so much so that i feels very binding in the rear a-arms. has anyone else experienced this and have they found any potential fixes for it?
svndayNZ is offline
Old 03-18-2014, 07:40 PM
  #6393
dan_vector's Avatar
Trader Rating: 27 (100%+)
Hi. Yes they are quite snug. A simple fix is to squeeze the sides of the track rod end while installed on the ball with soft face pliers. That'll free it up somewhat. Or you could just run the car and after a couple runs it'll free itself up anyway.
The is a 411 FF specific thread as well if you'd like to check it out for any other build tips etc specific to the FF. You can find it here http://www.rctech.net/forum/electric...-s411-fwd.html
dan_vector is offline
Old 03-18-2014, 08:18 PM
  #6394
svndayNZ's Avatar
thats awesome thanks very much mate. I'll check out the FF forum.
svndayNZ is offline
Old 03-21-2014, 10:35 PM
  #6395
Chiefy 707's Avatar
Hey guys I've been searching, is there a one way diff available for this chassis?
I haven't seen one listed under the option parts for any of the variants of the S411. Can a one way from another similar type TC be easily adapted?
Thanks in advance!
Chiefy 707 is offline
Old 03-22-2014, 08:36 AM
  #6396
dan_vector's Avatar
There is one for the S400. Not sure if it would fit the S411. If you search the serpent site for 'one way' it'll come up.
Old 03-22-2014, 10:33 AM
  #6397
Johnny Wishbone's Avatar
Default Shock Build
So I have been meaning to post this shock build that seems to work pretty good so far for me. Unfortunately, I had a few picsw to go with this, but the quality isn't very good and then the size was tto big to actually get them on here.
Reguardless, here is the build. I use the blue orings that come in the Traxxas #2362, along with these I use the shims from Yokomo ZC-S40 and finally I use the Tamiya bladders, (sorry no part number).
I only run one of the orings in each shock and use a spacer to take up the spacing difference as the Traxxas oring is quite a bit thinner. The spacer I use can be made up of either nylon shock spacers or washers, I use the nylon part to cut down on loose parts. The thickness should take up the thickness of one of the stock orings that you are eliminating.
Below the blue oring I use the Yokomo shim(s) and then the lower shock cap. The shims do a couple of things and allow you to do a bit of leak control and drag control. Because the shims outer diameter is a perfect fit for the outside but has a little larger inner hole for the shaft to slide thru. By doing this it will squish the oring on the outer diameter and tighten the inner hole, thus giving a better seal. I started off using a 0.5mm shim which worked very good. The nice thing is that the other thickness shims allow you to add or subtract to get a controlled tightness on the oring.
If you feel that a single oring isn't enough you can double up on the blue oring. Running a guide washer, oring, shim, oring, shim. The nice thing about these orings are that they are like a xring, or two small lips for seal. They also are quite a bit thinner than a normal oring so it gives you some room to play with the shims. I have also found they don't seem to swell or harden up as bad as some of the alternates.
I use the Tamiya black bladders just beacuse I like the feel of them a little better and the rounded lip on the outer ring make them easier to put the cap over them. I also have the Yokomo clearsh blue bladders, but haven't tried them out yet, but I think they can be a good substitude for the Tamiya ones. The one thing I find with the Tamiya bladders is that I can get a shock with less rebound than when using other bladders. I may try the bladders that come with the Traxxas oring kit above, but again haven't had the chance to try them yet.
Johnny Wishbone is offline
Old 03-23-2014, 12:41 PM
  #6398
Chiefy 707's Avatar
So now that leads to my next question. How different are the bulkheads between the S400 and S411?
Thanks!
Old 03-26-2014, 05:41 AM
  #6399
tiago890's Avatar
Hey Guys,
Cracked my top deck at this past weekends race, managed to glue it together along with some fiber tape to let me finish the day, but hurt me in the long run as car was getting to much flex, in need of a new top deck and was wondering what you guys would suggest to get, local track is small, 80' x 40' and technical, was running the stock top deck that came with the TE. Suggestions are greatly appreciated.
Cheers,
tiago890 is offline
  #6400
tiago890's Avatar
double post
tiago890 is offline
Old 03-26-2014, 09:41 AM
  #6401
Byronf1's Avatar
Originally Posted by tiago890
Hey Guys,
Cheers,
What kind of surface you are running on? is it high grip or low?
Byronf1 is offline
Old 03-26-2014, 12:59 PM
  #6402
tiago890's Avatar
its carpet, and usually takes a spray of sxt before we run, so usually high grip especially when the temp starts warming up through out the day
tiago890 is offline
Old 03-26-2014, 02:09 PM
  #6403
Byronf1's Avatar
Does someone is using hudy servo horn on the Eryx?
Byronf1 is offline
Old 03-26-2014, 02:13 PM
  #6404
Byronf1's Avatar
may be you should try the hard wishbones... and the hard top deck 401431 if you are experimenting too much flex...
Byronf1 is offline
Old 03-27-2014, 12:04 AM
  #6405
JAM Racing's Avatar
Thanks!
S400 is about 4 to 5 mills wider across the bulheads ..havnt measured the rest
all the best
JAM Racing is offline
