Like Tree16Likes
Serpent S411
Old 06-26-2011, 02:02 PM
  #421
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by RC MARKET
today MOD. Class 1st & 3rd !
Awesome
Jamison R is offline
Old 06-26-2011, 05:36 PM
  #422
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
S411 Kit instock !
Are they running the box stock chassis?
OVA is offline
Old 06-27-2011, 12:08 AM
  #423
RC MARKET's Avatar
Option 2mm chassis !
RC MARKET is offline
Old 06-27-2011, 04:32 AM
  #424
Jamison R's Avatar
Why is your web store so slow? I have tried to order spare parts for s411, but your website is so slow. I give up. Twice.
Stormer is supposed to have car and parts this week.
Old 06-27-2011, 04:33 AM
  #425
Jamison R's Avatar
Old 06-27-2011, 04:45 AM
  #426
I swear it runs on dial-up. I usually do orders from there while using the computer for other things... It makes the 5min page refresh fly by much faster.
Dragonfire is offline
Old 06-27-2011, 04:54 AM
  #427
Jamison R's Avatar
I dont have your patience. Anyone in the US interetsed in a S411?
Old 06-27-2011, 05:17 AM
  #428
daleburr's Avatar
Worst website ever. I have no idea why (or how) anyone buys from it.
daleburr is offline
Old 06-27-2011, 05:58 AM
  #429
Jamison R's Avatar
RCMarket. Fix your super slow website and you may make some more money.
Old 06-27-2011, 06:22 AM
  #430
RC MARKET's Avatar
OK !
Our S411 is 2.25mm Carbon Chassis
Old 06-27-2011, 06:35 AM
  #431
venom54's Avatar
Default S411 PARTS
I dont have your patience. Anyone in the US interetsed in a S411? I have a brand new one for sale.
Mate, what parts do you need. We have a lot in stock here in OZ (Aus). And we ship world wide.
Cheers
Ren
RAB HOBBIES
venom54 is offline
Old 06-27-2011, 06:45 AM
  #432
Akhor's Avatar
And it only works in Internet Explorer...
Akhor is offline
Old 06-27-2011, 07:50 AM
  #433
JayBee's Avatar
Trader Rating: 31 (100%+)
I should be getting 2 of the 3 orders I've placed with RCMARKET this week. My experience has been fine thus far.
JayBee is offline
Old 06-27-2011, 09:27 AM
  #434
Jamison R's Avatar
Cheers
Ren
RAB HOBBIES
I am going to ROAR nats in late July. Im gonna need front and rear arms, steering knuckles, C-Hubs(4 degree), rear uprights, steering bushings, belts, and ball cups. Also the bigger inner bearing for axle's.
Old 06-27-2011, 11:00 AM
  #435
Have been doing a bit of running with this car now and have learn't quite a bit. The gear diff is still a bit of a question mark for me though... I now have 3000cst in there and it keeps feeling better and better to drive the heavier I go BUT I can feel the steering drop away. Has anyone tried running 4 bevel gears instead of the kit 2? What did you think?
Also... have played with kit springs a bit and I strongly recommend changing out the rear spring for something more progressive. I have been playing with the Hara springs personally but it seems a necessity to get a solid rear end. A harder front bar (or softer rear) gives the car better balance mid corner too so try a 1.6 front or 1.2 rear.
Hello all,
Chris Kerswell and I both ran our S411's for the first time yesterday. Like you we found that going to heavier diff oil transformed the car. We got as far as 2000, but nobody had anything heavier at the track and we didn't have the parts to try 4 bevel gears. We are thinking along exactly the same lines as you. We're not sure that 2 gears with 2000 is equivalent to 4 gears with 1000, but we're pretty sure a 4 gear setup will result in a more viscous diff.
We will be trying the 2mm and 2.25mm chassis versions when we get them through. Chris also has some stiffer wishbones coming to try. I'll try and post our findings here once we've drawn some meaningful conclusions from the tests. I think in the long term a range of different hardness wishbones will be made available to allow you to fine tune your S411 to specific tracks and conditions.
Chris ran Hara grey springs and I started on hara blacks. We chose to run with what we know in the beginning and will do back to back comparisons with the serpent springs soon.
The driveshaft blades are very soft. In mod with a 4 turn motor they were lasting less than 2 runs. Harder ones are on the way but until then we've modified TC6 ones to fit and they seem fine. You just need to sand them a bit and run a 2mm drill through the holes.
Overall we have been very impressed with the quality of the car. We have some work to do on setups and this will be our testing target in the next couple of weeks. As with any new car; it takes a little while to get properly familiar with everything, but we are very optimistic for the future.
Mark Stiles is offline
