Will this work?????? >
Old 01-27-2011, 09:35 PM
  #16
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by tunerjetta29 View Post
Looks to me like your running 9V through each LED only rated for 3.6V. They don't share voltage in a parallel circuit. Also your Ohm's law formula is the calculation for total resistance in a series circuit when you have clearly made a parallel circuit. Try again.
We have a voltage drop across the LED of 3.6V so there is 5.4 volts left to acount for. The voltage drop across the resistor is caculated by V=IR
Voltage = Current X Resistance). With the 330ohm resiter there will be a voltage drop of 6.6V, Idealy a 270 ohm resistor will give you the 5.4 volt drop needed but with the % of tolerance 270 ohm resistor may allow too mutch current to pass so the next higest value is 330 ohm.
By the way I know ohms law, may be you should study it a bit more.
http://www.the12volt.com/ohm/ohmslaw.asp
BCbud is offline
Old 01-27-2011, 10:03 PM
  #17
xray09ACT's Avatar
erm......
wouldn't it be 135ohms and the best resister to use is a 150 ohm 1/4 watt?
The leds are in parellel so you have to work on the Rtotal and then presume, as per kirchoffs laws, that the current =0
You would also only need to use one resistor
xray09ACT is offline
Old 01-27-2011, 10:12 PM
  #18
BCbud's Avatar
Originally Posted by xray09ACT View Post
erm......
No, because in that aplication you are running the current of both LED's through 1 resistor and in my aplication the resistors are only seeing the current of 1 LED each.
BCbud is offline
Old 01-27-2011, 10:16 PM
  #19
HB Moose's Avatar
Not to give all my secrets away but there are lots of sites out there with LED calculators. First example I came too.
http://ledcalc.com/
HB Moose is offline
Old 01-27-2011, 10:17 PM
  #20
BCbud's Avatar
BTW, I chose not to do it that way because if 1 LED was to fail you then you would have too much current going through the last LED and it would fail as well.
BCbud is offline
Old 01-27-2011, 10:21 PM
  #21
BCbud's Avatar
http://ledcalc.com/
Yes, that is where I confirmed my calculations but some are not the electronic type so I chose to draw a schematic for him to folow to help make it simple ( I hope).
BCbud is offline
Old 01-27-2011, 10:23 PM
  #22
xray09ACT's Avatar
ok cool, that works.
you could also build in a 555 timer to ensure that you have the leds working and if they don't then they will click over to secondaries............
are we starting to overengineer here?
Old 01-27-2011, 10:25 PM
  #23
BCbud's Avatar
You started it LOL!
BCbud is offline
Old 01-27-2011, 10:28 PM
  #24
xray09ACT's Avatar
lol
No i didn't i simplified it by removing a component!!!
Old 01-27-2011, 10:31 PM
  #25
BCbud's Avatar
Read the link that HB Moose posted, LED's need some kind of current limmiting.
BCbud is offline
Old 01-27-2011, 10:36 PM
  #26
BCbud's Avatar
This is a better one.
http://www.daycounter.com/Calculator...lculator.phtml
BCbud is offline
Old 01-27-2011, 10:52 PM
  #27
BCbud's Avatar
lol
Sorry, I was refuring to your first post, not the one with thw schematic. You are correct in it is a bit simpler but for the reason I all ready stated, the addition of 1 resistor I think is a better solution.
Again, I apologize for my misunderstanding of your post.
I try my best helping others out when I can but I will make mistakes once in a while.
BCbud is offline
Old 01-28-2011, 12:49 AM
  #28
xray09ACT's Avatar
all good mate, ozzy sarcasm
