What do people do between races ? >
Old 01-15-2011, 10:15 AM
cyclone speed's Avatar
Default What do people do between races ?
Hello,
I have been asking myself this question, what do people mostly do between races ?
I see them ( people at my track or at important event such as IFMAR ISTC ..... ) bent on their cars with wrench and stuff, but when you ask them, they say " i havent changed my setup much " . If they haven't changded it, what do they do for 40 min ?
cyclone speed is offline
Old 01-15-2011, 10:26 AM
Foxxrocket's Avatar
You can read about that here.
Foxxrocket is offline
Old 01-15-2011, 10:33 AM
sosidge's Avatar
Mostly I sit on my backside and rifle through my lunchbag.
sosidge is offline
Old 01-15-2011, 04:38 PM
Potoczak's Avatar
Trader Rating: 120 (100%+)
Clean my pit table.
Potoczak is offline
Old 01-15-2011, 07:35 PM
In between heats I either work on the car to get ready for the next heat and/or socialize.
In between races I usually go home and to work the next day.
AreCee is offline
Old 01-15-2011, 07:47 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
"i havent changed my setup much" is hilarious to me.
I've heard it so many times yet when the changes are listed, its HUGE to change the way their car drives.
R3VoLuTiOn is offline
Old 01-15-2011, 08:06 PM
mickrcarver's Avatar
Trader Rating: 98 (98%+)
clean the fuzz out of my car cause are carpet is blue and sux
mickrcarver is offline
Old 01-15-2011, 08:10 PM
JamminSP's Avatar
If time allows between heats and the mains I will do a full teardown... inspection and reassembly... If I cant do a full teardown I will atleast check the diffs, shocks, gear mesh etc. In between race weekends I definately do a full teardown and replacement of all bearings, rebuild the shock and diffs and replace any worn parts.....
JamminSP is offline
Old 01-15-2011, 08:13 PM
treborwd22's Avatar
First I turn marshall. Then I go to my pit table and try and figure out what caused me to not finish the race
treborwd22 is offline
Old 01-15-2011, 10:05 PM
Trader Rating: 14 (100%+)
Marshall, have a Newport, check out some of the scattered housewives around there.
DuckStang is offline
Old 01-15-2011, 10:18 PM
Jscott54's Avatar
Smile
I first marshal then I put my car on the charger "Because changing the battery in a B44 sux" then I go over every inch of my car and make sure every screw is tight,Change tires then I go race and do the same thing.
Jscott54 is offline
Old 01-15-2011, 10:41 PM
LOSI123's Avatar
Trader Rating: 63 (100%+)
Check this out
Also check for loose wheel nuts and screws around the car, clean the tires & binding in suspension from bent hinge pins if you had any crashes
I was bored one night, and made it in a rush
http://www.youtube.com/watch?v=sHdoV...eature=related
LOSI123 is offline
Old 01-15-2011, 10:58 PM
Suspended
Originally Posted by cyclone speed View Post
Hello,
or
PFKAOG is offline
Old 01-15-2011, 11:06 PM
pakk's Avatar
Trader Rating: 80 (100%+)
I practice on the off road track.
pakk is offline
Old 01-15-2011, 11:38 PM
andrew-01's Avatar
Trader Rating: 22 (100%+)
Turn marshall and then finish my bag of Hot Cheetos.
andrew-01 is offline
