Team Corally RDX Touring Car >
Old 03-01-2005, 07:10 AM
  #1216
Default RDX Body
Re: Alfa Body
I'm thinking of trying a different body on my RDX rather than the Parma Alfa. Has anyone used the new Protoform Stratus 3.0.
I just picked one up this weekend so see how it fits.
FYI-the pre drawn wheel wells fit exactly on the RDX (if you use one clip on each side of the arm) and the hood of the body complensates for the shocktower (ie. no shocktower modification necessary to slam the body).
Does anyone have any comments? Thanks!
Electro-MAX RC is offline
Old 03-01-2005, 07:30 AM
  #1217
Turbonium's Avatar
Trader Rating: 27 (100%+)
i used a 3.0 last weekend... worked well on concrete, and i used it on carpet in january on a different chassis...
they say its supposed to be a good carpet body.
Turbonium is offline
Old 03-02-2005, 07:36 AM
  #1218
Jeff Brown's Avatar
Jeff Brown is offline
Old 03-02-2005, 07:44 AM
  #1219
Has anyone tryed the lowered suspension blocks on the front only to improve turn in? Is there a better way to improve low speed cornering?
ukeejim is offline
Old 03-02-2005, 07:45 AM
  #1220
Jeff Brown's Avatar
At the snowbirds all the modified drivers were running optional blocks in the front and stock roll blocks in the rear.
Jeff
Old 03-02-2005, 07:47 AM
  #1221
rayhuang's Avatar
I like the mid ackermann position the best and less caster (4 deg w/ antidive.) YOu cant try that. I never never tried the LRC blocks so I cannot comment on those.
Ray
rayhuang is offline
Old 03-02-2005, 07:48 AM
  #1222
Turbonium's Avatar
so they were running the #1 position low block in front, and the #1 position stock block in rear?
just curious, as i am heading to a track this weekend that uses the same carpet as the 'birds.... although, not mod, prolly 19T and stock.
Old 03-02-2005, 09:39 AM
  #1223
The Teacher's Avatar
Trader Rating: 62 (100%+)
I've tried the stock blocks in the front (#! position), the low blocks in the front (#1) position and I've also tried the low/stock block combo to get anti-dive. On a low to medium bite track with tight corners I've found the low blocks provide the best stearing(fastest lap times also...).
The Teacher is offline
Old 03-02-2005, 09:57 AM
  #1224
Jeff Brown's Avatar
Default Roll Center Numbers
The numbers for roll centers only relate to the stock blocks in the car. Positions 1 & 2 are for the bottom holes and Positions 3 & 4 for the upper holes. Positions 2 & 4 refer to the blocks being flipped.
The optional blocks are not a number, technically it would be like a 0. So, in that case we were running 0 all around in the front and 1 all around in the rear.
Jeff
Old 03-02-2005, 11:35 AM
  #1225
Turbonium's Avatar
gotcha.. last time i was on foam/carpet, i was running 0 all around, then. low blocks, all flipped. i may try the rear up this time. thanks!!!
Old 03-02-2005, 12:12 PM
  #1226
what are block when you put them on the top of the car ha
Young GUN is offline
Old 03-03-2005, 08:06 PM
  #1227
Registered User
Anyone know if the 4mm chassis and 3.5mm top deck part numbers and availability? Also where do you guy mesure your droop settings?
This chassis is just awsome,many local guys have a hard time to folow me it's just so dialed.
pipih2000 is offline
Old 03-04-2005, 01:39 AM
  #1228
cooliomojo-CEBU's Avatar
dont want to be redudant but please help me out......need info because am planning to get new kit.....
what are the strengths of the RDX?
how is it compared to the xray, 415 or the new losi...
your input will be highly appreciated.
cooliomojo-CEBU is offline
Old 03-04-2005, 03:58 AM
  #1229
Man I got my 4mm chassis for the RDX last night.......SWEET!!!....
Old 03-04-2005, 06:49 AM
  #1230
rayhuang's Avatar
Post a few pics if you can!!
rayhuang is offline
