Team Corally RDX Touring Car
#1966
Re: NEW PRODUCTS ON THE WAY!
Originally posted by CorallyUSA
Alright........ a lot of product coming our way next week. The following items will be available.
Hauler Bags
Transmitter Bags
Aluminum Power Cases
00166 Kits
00166UK Kits
00167 Carpet Spec Kits
Corally BLACK SERIES 19T SPEC
CERAMIC Thrust Bearings
3.9mm Milled Carpet Chassis
Don't forget about the current NEW Products already in stock.
1.6mm Front and Rear Swaybars
White Machined Delrin 1 piece Pulleys
GP3700 Battery Packs
MMS3 Speed Controllers
2.4mm Chassis for Asphalt
Hauler Bags
Transmitter Bags
00166 Kits
00166UK Kits
#1967
Thanks Jeff
#1968
Quick question, I noticed that the manual shows the guide for the belt at the front. To fit this I had to change the Diff(or spool) the otherway around, ie wide side to the right, opposite to the rear(as shown in the manual), is this what other people have done ? - thanks Andy
#1970
Many thanks - Very good car
#1974
Same if you are using a diff and a spool, or a diff and a one-way. The front belt has to be on the inner pulley on the layshaft.
Jeff
#1975
This now looks correct
#1976
Jeff or CorallyUSA, I didn't get a chance to call about some parts. I might be making a road trip to the shop on Friday. I am putting a diff in the front end and would like to know if you all have most of the parts for a complete diff. I have an extra one piece pulley that I will be using and just need the rest items. I'll check here or try to call before I leave...
#1977
We have all the parts seperately..... but I think it is cheaper to just buy a new lightweight diff and use the one piece pulley.
Jeff
Jeff
#1978
Cool, thanks if everything works out at work I'll be there tommorrow...
#1980
3 shims...... 1mm each on each of the roll center blocks. 12 shims on the front end to widen it.
Jeff
Jeff
