Team Corally RDX Touring Car
#9091
so a narrower front tire nets more steering? Just as a counter point wouldn't a wider tire offer more contact patch thus giving more steering?
Has anyone tried the new arms with the new narrow hubs? Still ahve this problem? I prefer not to have to trim plastic off my tires, I guess I'm just anal like that. I am still holding out for the parmas to have a bit more offset.
Thanks for the info though bill. Im always open to new ideas. And is you ask Mr. McGoo I am always thinking wich according to him is NOT agood thing. I talk his ear off when we pit together at our LHS boucing ideas off him.
#9092
Hello all,
1. Just wondering if there is an optional (smoother/stronger/ceramic?carbide?) thrust bearing assemble that is recommended.
2. How many cone washers are recommended...4,5, or 6?
3. Lastly, has anyone used/prefer the axiom thrust washer.
Cheerz
Cheerz
#9094
Trader Rating: 102 (100%+)
question CVD
got a quick question ....did a search..but couldn't find the answer.
CVD's ...have to change one up front ..got a bit bent.
I have a few sitting in my box..but they are different colors...
i have a set of a purple tint
and a few sets of the blueish tint CVD
Is there a difference in material or is just one set is older than the other or something else.
thanks
thanks
#9095
Corally can't seem to make up its mind on what color it wants to anodize things. There's a light blue and a darker blue... both are duraluminum. The steel ones (which I highly recommend) are black. I haven't bent a steel one in a year since I switched. Good stuff.
To be certain, weigh them. The steel ones should be heavier, and the two you've got should weigh the same as the one you bent.
#9097
Originally Posted by tel
Jeff Brown,
A ways back you said you were checking on new mounting hardware for sway bars with the new 35 arms/wishbones. Any news on how to mount sway bars to the arms or new hardware? A picture would be fanatastic.
#9098
Check it out guys. New top deck on there with the center link steering...
#9099
Cool!
Is the center link and deck a bolt on? Available yet in USA?
#9100
Originally Posted by raffaelli
Cool!
#9101
Where did you get it?
#9102
Superior Hobbies / Corally USA here in Orlando, Fl.
#9105
79359B part number not listed!
