Team Corally RDX Touring Car
#9106
Something else I forgot to mention. With the offset bulkhead you have to remove some material from the top deck for it to clear.
#9107
Originally Posted by raffaelli
79359B part number not listed!
#9108
Originally Posted by TeamPink91
I just got mine today, and I live in the US. Yea it's pretty much a bolt on. All you have to do is use the left side bell crank and relocate one of the ball studs so they are both side by side, and then flip the bell crank post upside down so it screws into the topdeck rather than the chassis.
#9109
Well actually you do need longer turnbuckles, but yes that is the only thing you will need besides the topdeck. I assume the part number is different because it is a different top deck.
#9110
Registered User
Originally Posted by andrewdoherty
so a narrower front tire nets more steering? Just as a counter point wouldn't a wider tire offer more contact patch thus giving more steering?
Has anyone tried the new arms with the new narrow hubs? Still ahve this problem? I prefer not to have to trim plastic off my tires, I guess I'm just anal like that. I am still holding out for the parmas to have a bit more offset.
Thanks for the info though bill. Im always open to new ideas. And is you ask Mr. McGoo I am always thinking wich according to him is NOT agood thing. I talk his ear off when we pit together at our LHS boucing ideas off him.
#9111
#9114
just picked up a carpet spec version and have some questions...
what are the must have parts for this car on carpet?
it looks like most of the corally drivers are using the 4mm chassis, new short arms, the lowered roll center mounts and the long extended shock mounts. did i miss anything?
do i really need the 4mm chassis if i have the 3.4mm top deck? i would think the parts to have would be the short arms, lowered roll center mounts and the long ext. shock mounts.
are most running the new motor mount which brings the motor closer to center?
#9115
the CS kit is pretty good right out of the box. Certinly the Ultra Low RC blocks, Lowered front shock tower, and the new arms do not need the extentions.
As far as the 4mm chassis, we are getting away from it. I can't speak for the new motor mount as I have never tried it.
#9116
Originally Posted by alb
MUST HAVES........nothing.
#9117
Why are you getting away from the thick chassis?
#9118
I finally got a chance to run the RDX I bought. I was very impressed with the car. It was so quiet, and I used Brian McGreevy's set up under it and the car worked so nice.
The only thing I had trouble with is I lost the screw that holds the low blocks in. What are you guys using for loctite to hold that kind of stuff in?
#9119
BTW, I just got a report from Vegas. It seems the Xray guys are going back to the standard T2 chassis instead of the new solid one. Just another tidbit on "flex is good".
#9120
yeah, rumor has it that after the whole first day of racing, traction is still pure crap out there.
