Team Corally RDX Touring Car
#6031
Where are the RDX X-Long Shock Extensions used and mounted ?
#6033
Originally Posted by Sushi Boy
Hey woody,
So what are you setting your belt tension at? I still have the original belt on my car... and it's over a year old. I habe my layshaft all the way up... but no additional tensioner.
-Korey
-Korey
Right now I have the layshaft about the middle to see if that helps making it a littler looser, since tighter seemed to make it worse. I really think the only time its happing is when my batteries move around and push into the belt, they jam in there sometimes so bad, that the belt actually touches the pinion!
Woody
#6034
Originally Posted by EricO3
I've never had my belt flip over. I run with layshaft 3/4 up and no tensioner. Everytime it flips, do your batteries always hit it? Are you sure the your differentials are put in you bulkhead correctly (They're off set and the front one has to have the long side to the passenger side, and the rear have the long side to the driver side.)
-Eric
-Eric
Woody
#6036
Korey thanks for the tips on the C027 both of my motors where fast. I didn't have my drill bit so I put a vertical slot in the motor instead. I ran my rubber and foam car tonight and both where fast. I was using your setup from the NWICS race but couldn't get the car to turn in the infield, at first I thought I was being out motored but on the straight away I was just as fast. Then I remembered you are using a different chassis so I made a few changes and the car was awesome I ended up turning 33 laps in foam stock and 31 laps in rubber stock.
Driving the Corally has truely made racing electric sedan enjoyable. I can no longer say running nitro is a lot more fun.
#6037
Hmm weird.... What battery bars are you using?
-Korey
-Korey
Woody
#6038
-Korey
#6039
Try running Tamiya 3 hole pistons in the shocks. You'll have to put a few motor shim under the piston to take up some of the slack. They are thinner.. but have the same outder dia. They just seem to work better on our track at the moment. I also have been running 30 lb front springs with the shocks layed down one more hole on the tower. This helps the car steer a lot better in the middle and exit of the corner. I also went back down to 4 degrees of caster, this helps produce the additional low speed steering and turn in we need on the new track layout. It keeps the body roll down a touch too.
-Korey
-Korey
Everyone seems to post that the Tamiya pistons are better but can ANYONE tell me why please ?? I really want to know why they should be "BETTER"
#6040
Originally Posted by Merciless
Could you please post your rubber stock set-up ??
It is not that they are "better", it is just different.
Jeff
#6041
hey jeff do you when the snowbird set-up from all the rdx factory driver will be on the corallyusa site??
Thx
Later!
Thx
Later!
#6042
Shock Oil FT and Rear 30 wt
Springs FT 22lb Rear 19lb
Shims under Couplers: 1 I am going to try 2 next time I race but the car is good already
Shock mount position: Top 2nd hole in FT and Rear
Camber Link position: bottom 2nd hole FT and Rear
Toe Out FT 0 deg
That is it everything else is the same tires, inserts and everything else on the sheet. With the setup I have been running the car is easy to drive and fast I can put it anywhere on the track. It is almost like a little man is in the car driving it because at times I can't believe it is me. Such a vast difference from the other car I drove.
#6044
Originally Posted by Brian McGreevy
T1Raycer,
The car just works great everywhere we take it.
ill take a look at the setup from Novak!!
Thx Brian
Later
#6045
Thanks guys,
So with the tamiya pistons the shock "LOCKS UP" faster . Yes this would make the car more responsive I know alittle more now about why the guys are running them cheers
"Shims under Couplers: 1 I am going to try 2 next time I race but the car is good already" could you explian more on this i don't really understand what you mean or should i say where the shims go
Thanks for the set-up pointers also
Rod
Rod
