Team Corally RDX Touring Car
#4801
well i never had it on there to begin with, guys at my track said it shouldnt be on there.
I am just frustrated cause i have tried a couple other guys setups at my track and the car still rolls over,,,, i dont know if it maybe my not that good radio or what,,, but no matter what i do it will not stay on all 4's when traction comes up.
#4803
thats not it LOL i check the car after each run . It has to be something small i am not doing correctly or something stupid like that i know it.
#4805
rdx
Hello new to the rdx seen I'm also going to start with Robs setup can someone tell me what else I need to do Ie: tamiya shocks 2hole 3.9mm chassis spool,diff,1way for stock rubber...correct me if I'm wrong droop/downstops at 5mm ride Height and 7.5mm downstop thats 2.5mm droop right.....I currently run a 415 and never run this less of droop but this is a new car and I want to get it right all and any help will do if I can get this car going I will run it at the Novak and not the 415
#4807
Give Shane @ IRP a PM. He is working on a one way setup that is super easy to drive and fast! He might help you out, if you promise not to out qualify him @ the Novak!
#4808
hey guys, got my uk spec corally rdx and well impressed.
Plan to run the novak gtb brushless 5.5 velocity kit.....
anyone got any pictures with this bertha of a speedo fitted as cant seem to shooehorn it all in..
would br great to have a layout pic
cheers
cheers
#4809
My 1 way is no good speedtech doesn't have em where can i get 1 and how do I need to shim the tamiya shocks thanks
#4810
cheers
cheers
#4811
Originally Posted by koabich
I am not sure you'll, find the answer to that here. I cannot think of anyone that runs Tamiya shocks on the RDX as the Corally shocks are just as good.
Yes you need to shim the piston as it is just a bit thinner than Corally pistons I forgot which washer I used. Just find some that will fit and are not binding the piston.
Hope that helps,
-Shookie <><
MERRY CHRISTmas.
#4812
Hiya guys im about getting to grips with the RDX but in general i need to ask question about Droop and how do i adujust it? Correct me if im wrong but is it where you can move the angle of your wishbones on the bulkhead? Thanks,
Wills
Wills
#4813
Jeff
#4814
Wills
Wills
Jeff
#4815
Thanks Jeff
