Team Corally RDX Touring Car
#4786
Originally Posted by Brad_C
Pezz & Number 11,
When you get your cars in I will give you a set up that should work great for you.
Brad
Brad
#4787
NOW BACK IN STOCK
Lowered Towers - 79238
Hardened Diff Bolts - 77162
Ceramic Diff Balls - 1010
Standard Towers - 79239
Short Outdrives - 79191
Battery Only PowerCases - 90215
19T SPEC Motors - 381916L
SP12M Euro Kits - 00058
Super Glue - 13090
All parts supply is set and everything ready to go for 2006. In stock for immediate shipping. There will be some new items coming soon from Corally and Specialized RC. Keep your eye out in the next week or so.
Super Glue - 13090
#4788
my new avantar hehe!! in the small one its hard to see but here a big one hehe!! pretty cool!!
#4791
I'm not trying to stir the pot again, but I am trying to add 2 and 2 in my little mind. Corally has said that there is no new car coming out but that we should expect new things from Specialized. I'll assume that the new motor mount is one of these items which I believe requires a new chassis. I also see a lot of new cars moving towards easier maintenance with bulkheads that pull the diffs from the top. (Corally next?) Since they have already proven the car to be very capable and continue to update kits every time a better product comes along (ie.. white diff gears, 1.3 pistons, diff bolts, etc.) so can we expect the new kits to be updated with these parts, or will these strictly be optional items such as the 3.9 chassis?
#4792
Has anyone had problems with traction rolling, when running the rob michael setup on rubber tires on high bite carpet ?
#4793
Any upgrades sold through CorallyUSA/Specialized RC are just that, options that we developed seperate from Holland.
Jeff
#4795
Well, if you are using his EXACT setup, here are some more suggestions for you. Rob's setup seems to have A LOT of droop. Also check out Jason's setup from the IIC. Which is similar, but I think Vegas was higher bite than Novak.
Try 60 or 70wt in the front.
Try 26lb or even stiffer springs.
Try removing droop to about 1mm F/2mm R (up travel)
Try the 1.9mm swaybar on the front
Jeff
#4796
Thanks jeff yeah scotty has the new carpet now and so does my local track, jasons setup says he ran tamiya 2 hole pistons, do those have to be shimmed at all ? or do them fit right in there
#4797
I didn't realize that it worked that way. Thanks for the update and continue the great work. Lookin forward to more great products.
As far as items to come....... they will be from Specialized R/C and Corally direct. Just more option parts. No new car, no need for one.
Jeff
#4798
Jeff
#4799
jeff if you get a chance can you ask rob if the sheet is correct and that he did use a roll bar in the rear as well ?
#4800
Jeff
