Ofna Ultra GTP2e >
Ofna Ultra GTP2e
Ofna Ultra GTP2e
Old 03-13-2011, 12:28 AM
  #616
simplechamp's Avatar
Trader Rating: 73 (100%+)
That's what I was going to suggest too, heavier weight diff oil.
And as you said, there are a lot of variables: different tracks, different setups, different driving styles. A center diff may work great for one person but perform poor for another. It's all a matter of personal preference and what works best for you.
simplechamp is offline
Old 03-14-2011, 04:18 PM
  #617
snellemin's Avatar
Trader Rating: 16 (100%+)
I prefer the spool/solid diff in my GTP's and center diffs in my offroads. I use both plastic and metal spurs. The plastic spur is lighter and it's what is used when I drag raced the bugger. Cheap pinions last with the plastic spurs and the spur last too as I don't go offroad with my GTP.
Rattle can paint job on mine.
snellemin is offline
Old 03-14-2011, 05:10 PM
  #618
rcwck's Avatar
[QUOTE=snellemin;8801105]I prefer the spool/solid diff in my GTP's and center diffs in my offroads. I use both plastic and metal spurs. The plastic spur is lighter and it's what is used when I drag raced the bugger. Cheap pinions last with the plastic spurs and the spur last too as I don't go offroad with my GTP.
Sweet Tribal graphics. Blacks my fav but too hard for me to see on black asphalt. That PF body looks like a Audi in the front. I like em.
Do you think the stock diff rings will hold up for road racing ~2000kv 4S lipo? Assuming properly shimmed. I'm aware of that hardened steel ring OFNA upgrade. Is there a hardened pinion(13t) upgrade? I had to update both ring and pinion in my Kyosho nitro GT8.
rcwck is offline
Old 03-14-2011, 06:24 PM
  #619
snellemin's Avatar
Don't know much about your diffs as mine are the 44/14 version and not the buggy 43/13. The diffs in your should hold up. It's a different story when doing more powerful setups.
Old 03-15-2011, 02:44 AM
  #620
Jspeed's Avatar
Here's some food for thought for ya'll.
Jojo E's & Nelly Cruz's latest Ipanema Blackhawk Warrior creation.
Jspeed is offline
Old 03-15-2011, 02:48 AM
  #621
I like the adjustable downforce wing. Is that a stock feature or custom? Either way, easy to do.
Old 03-15-2011, 03:49 AM
  #622
Jspeed's Avatar
The one that comes with the body is smaller, some have won races without it too. Love that paint work.
Jspeed is offline
Old 03-15-2011, 09:46 AM
  #623
snellemin's Avatar
That adjustable wing is a nice add on, but that painjob is tight mang. That silver pin striping is sharp.
Old 03-16-2011, 08:50 AM
  #624
FangsCPO's Avatar
That is a badass paintjob. Did you need to mod the front foam bumper for the body to fit correctly?? I've thinking about a new lid. I'm on my second protoform and ready for a different look.
FangsCPO is offline
Old 03-16-2011, 08:53 AM
  #625
FangsCPO's Avatar
Originally Posted by snellemin
What's your ride height?? It's looks a little high or is that just to show off the badass looking new lid.
FangsCPO is offline
Old 03-16-2011, 11:37 AM
  #626
snellemin's Avatar
Chassis is 5/8" off the ground for now on this GTP. My other one is a tad lower. It might look higher due to the wheel wells.
Old 03-16-2011, 06:59 PM
  #627
Jspeed's Avatar
We offer matching CNC cut 1" foam bumpers for Warriors, designed to protect your body & chassis during impacts. They also help to reduce air from getting under the lid and help produce increased steering at hi-speeds. They’re very nice too, when ordering please specify for DM1S or IGT cars. Thanks.
Jspeed is offline
Old 03-16-2011, 08:59 PM
  #628
FangsCPO's Avatar
I'm sorry, order from where??
FangsCPO is offline
Old 03-16-2011, 09:17 PM
  #629
Jspeed's Avatar
Actually, my fault.
Where to buy
Jspeed is offline
Old 03-18-2011, 02:13 PM
  #630
snellemin's Avatar
Exclamation Timing boost for low kv motors in light weight cars
So in the little bit of free time that I have for myself, I got busy with the goal of measuring timing boost/cheat/ turbo with low kv sensored motors. Results were great. But alas my datalogger has a hiccup with it's software and I can't show proof of my datalogs.
Test was done on a FLM Rustler, Tekin 1400kv buggy motor, MMpro, 58/25 mod.8 gearing and 4s Lipo.
4s Regular 10 degrees timing was a bit more than 22000 rpm.
4s CHEAT 30 degrees timing was a bit more than 33000 rpm.
Cheat 50 degrees timing on 2s was a bit more than 33000rpm. This was pulling 70+ amps and got hot really fast. The MMPro was crying at this point.
So it looks like I went from 1400kv to 2000kv with 30 degrees timing. Pretty cool.
Motor temps and ESC weren't high at all.
But this is a great feature to mess with your 1/8 onroad monsters. Now you can set the rpm when to accelerate and how quick just like the 1/10 folks. With the lower kv motor you gain some additional torque for coming out of corners. And you can pull it off with a cheaper 1/10 ESC.
