Ofna Ultra GTP2e >
Ofna Ultra GTP2e
Ofna Ultra GTP2e
Old 05-21-2011, 01:46 AM
  #766
ldivinag's Avatar
Originally Posted by Timbulb
1. How much play do you guys have in your front drive shaft? Mine seems almost too short. It moves a good half inch forward and backward like they installed a driveshaft of the wrong size. The rear one is fine and only moves a fraction of an inch. This is creating a lot of drivetrain noise. Is it possible they installed the wrong size?
on my AE sc10, the manual says to stick some o-rings in there to act like a thing to force the rear drive shaft just enough so it doesnt bottom out but give enough give when it does...
mine moves about .25"..
2. My wheelnuts seem to loosen very easily. Will notching the wheelnuts remedy this?
i just bought a 17mm socket along with a stubby socket wrench so i can crank down on that nut...
try putting just a dab of blue locktite... just a dab.
ldivinag is offline
Old 05-21-2011, 07:42 AM
  #767
Timbulb's Avatar
Here's my GTP2E
Timbulb is offline
Old 05-21-2011, 08:01 AM
  #768
Timbulb's Avatar
I've done the o-ring thing on my vehicles before, but these are huge compared to all my1/10 vehicles. I'll have to just look for some bigger o-rings I guess.
Timbulb is offline
Old 05-21-2011, 02:08 PM
  #769
ldivinag's Avatar
try this:
goto a sporting goods/gun store store and look for the disposable ear plugs. they are like soft foam thingees that you twist and distort to fit in your ear canal.
just cut it and shape it so it fits in the drive cup...
ldivinag is offline
Old 05-21-2011, 02:17 PM
  #770
Timbulb's Avatar
Excellent idea! Thanks.
Timbulb is offline
Old 05-23-2011, 02:14 PM
  #771
Timbulb's Avatar
What is the biggest pinion that will fit on the GTB2E?
Timbulb is offline
Old 05-24-2011, 01:33 PM
  #772
with the 51 tooth i was barely able to get the 26t on, im probably going to have rc monster modify my spare spool to fit the traxxas gear then ill be able to fit bigger but ill probably go down to 23 and use the 36t spur for speed runs
scrivtwin2 is offline
Old 05-24-2011, 01:34 PM
  #773
Trader Rating: 30 (100%+)
so how do I get more info on this modified spur gear. I've emailed rc-monster with no response ????
darinm is offline
Old 05-24-2011, 01:41 PM
  #774
i dont knowlol i was just going to try and email themlol
Old 05-24-2011, 01:49 PM
  #775
*JayVee*'s Avatar
Trader Rating: 40 (100%+)
I am working on it fellas... Calm down... I already bought my iNTEGY spur just the other day... BUT!!! I also have my GTP2e on eBay and its doing quite well...at $510+... So, my SPEED days may be counted within 2+ days left in auction...
*JayVee* is offline
Old 05-26-2011, 04:03 AM
  #776
hello,
GTP2 on, I think the front is very soft. Is that there are other springs as an option?
What did you put as oil shock absorber in the front?
By cons back seems fine.
Thank you
PS: You have a basic setup?
keopscav is offline
Old 05-28-2011, 12:12 AM
  #777
ldivinag's Avatar
Originally Posted by keopscav
hello,
Thank you
manual lists 40 as oem shock oil.
somewhere in this thread, i heard going to 70 for the fronts...
ldivinag is offline
Old 05-29-2011, 03:12 AM
  #778
jones8352's Avatar
Default Tire question
I just got a set of Ofna belted street tires for my Vorza. Can someone tell me whats up with the foams? It came with two strips of foam. I tried to get both of them inside the tire and it looked like the smaller foam was wadded up. I'm from offroad land so please excuse my ignorance of onroad products. I've been looking at these gtp3e's and I don't see how my fleet could go without one of these jewels! LOL Plus there's a onroad race track near by.
Jerry
jones8352 is offline
Old 05-29-2011, 08:55 AM
  #779
ldivinag's Avatar
Jerry
The smaller one goes on the wheel the middle. Manual tells you glue the ends together to they form an O and.then you place bigger one on top and.glue the ends also.
Then place the tire one wheel. Without the smaller one, when you mount just the bigger one you can feel a "void" down the center...
Make sense?
ldivinag is offline
Old 05-29-2011, 05:03 PM
  #780
jones8352's Avatar
Make sense?
I tried that before I posted here. I didn't have any luck installing both foams. I ended up using the wider foam, they seem ok and I'll only be using for speed runs so I hope I didn't screw up too bad. Thanks for your imput, I really appreciate it!
Jerry
