Like Tree4Likes
Tamiya TRF417
Old 10-14-2010, 01:17 AM
  #106
kentech's Avatar
http://www.ustream.tv/recorded/10188505
Around 13 minutes and also 26 minutes in you can see the TRF department from the Hobby Show...you will see the TRF417 with all new parts laid out separately there...
kentech is offline
Old 10-14-2010, 02:14 AM
  #107
Taman's Avatar
Trader Rating: 67 (100%+)
Nice find and thanks for posting it around the 56min mark there is also an ad for the TRF 502X and TRF417.
Taman is offline
Old 10-14-2010, 02:54 AM
  #108
kentech's Avatar
The TRF vid is also available here in HQ:
http://www.tamiya.com/japan/hobbyshow/movie/trf.wmv
Alternatively http://www.youtube.com/watch?v=JJayzB5ZsZU
kentech is offline
Old 10-14-2010, 07:56 AM
  #109
Does anyone know if the front dogbones are aluminium or steel?
Mange is offline
Old 10-14-2010, 11:13 AM
  #110
Trader Rating: 47 (100%+)
hope speectech gets the pre order link up soon
transplantlife is offline
Old 10-14-2010, 11:15 AM
  #111
Hebiki's Avatar
Trader Rating: 26 (100%+)
coming soon... REAL SOON.
Hebiki is offline
Old 10-14-2010, 04:31 PM
  #112
veecee's Avatar
Trader Rating: 34 (100%+)
Here's an image of all the new 417 parts
veecee is offline
Old 10-15-2010, 04:38 AM
  #113
kentech's Avatar
Satoshi Maezumi car used at JMRCA Championship
New parts again:
kentech is offline
Old 10-15-2010, 09:29 AM
  #114
TryHard's Avatar
Interesting, as it looks like the centre pulley slots into the spur both sides... wonder if its all slotted together (using the centre bulkhead bearing spacing to hold everything together) , or screws are used... would be kinda cool to just be able to pull the layshaft out and change a spur without worrying about warping it by screwing it down too tight
I'm guessing the axle components are non set screw cross joints and holding sleeves.. not sure why a new axle is needed though, unless the sleeve is recessed into the outside maybe (knowing the TOP sleeves are tight in the hubs).
New diff halves, difficult to spot, but I know Elliott had been running ones with locking D rings this year... and thats the main change
On the chassis plate, one thing I've just noticed... the bulkheads are closer to together cross ways. The screw holes for the suspension blocks and bulkheads dont line up in a straight line like on the 416, with the bulkhead holes closer to the chassis centre line.. which is probably the reason for the new towers and upper bulkheads (look at satoshi's car, and the camber links are in the middle hole, at a guess thats the same position as the inner most hole on a 416) as well... pretty much no 416 bulkheads or towers are going to fit, so there's the new model designation reason!
Does look good though, lots of good small refinements...
Ed
TryHard is offline
Old 10-15-2010, 03:51 PM
  #115
Xchange's Avatar
Trader Rating: 10 (92%+)
In resume, the 417 ad new low deck, top deck, motor mount, pulley, diff bulkead up and down and new diff so for 250 bucks we can convert a trf416x ))
Xchange is offline
Old 10-15-2010, 04:21 PM
  #116
Taman's Avatar
With Satoshi Maezumi using the Gear Diff, will that mean that Tamiya may bring out their own verion? Time will tell I guess.
Taman is offline
Old 10-15-2010, 05:39 PM
  #117
superspeed's Avatar
wow, every latest tc has a super slim chassis. less material = cheaper price. i only hope that's true, lol.
superspeed is offline
Old 10-16-2010, 12:04 AM
  #118
kentech's Avatar
Ed
Exactly Ed! Looking good!
Believe the sleeve is recessed yes.
kentech is offline
Old 10-16-2010, 12:06 AM
  #119
kentech's Avatar
Some more photos.
A couple more @ http://kentech.blogs.se/
kentech is offline
Old 10-16-2010, 08:45 AM
  #120
Hi Kenneth!
Finally a smaller (thinner) box on the TRF 417 which might reduce postage costs a little bit...
Tamiya continues to contribute to our addiction, right?
Great new products! I specially appreciated the new TRF 502!
Regards,
José Cordeiro is offline
