TAMIYA M-06 Thread
#1096
The rear weights help a lot! Without them you tune the car to make ensure rear traction and reduce oversteer, at cost of understeer. With them installed, you no longer have to worry about rear traction, so you can focus on adding front grip/ steering. I also ran the 1 degree hubs and reduced dual rate to 60% to minimise traction roll.
Tamiya will hopefully release these weights as a hop up option.
#1097
Raman,
if the car was good already, this is the key. driving practice can be adressed.
I know it can be very hard to race against FWD Minis, as the lines are quite different on tight curves and often a crash is the consequence...
Good idea with the shorty lipo. Gives a many opportunities to play with the weight balance. I´m running my Nimh complete to the rear, but the receiver in front. It always surprises me, how much steering the M06 can have with this "buggy" configuration, compared to my previous M04/M02.
I wish you all the best for your next race,
Matthias
Matthias
#1098
Hi guys,
Yesterday was Round 5 of our Tamiya Asia Cup. My daughter's M06 set the fastest laps for the day, qualified 2nd, finished 2nd overall.
Getting there.
Getting there.
#1099
Hi guys,
Getting there.
Getting there.
Did you use some R-spec hopups?
fastest lap must feel very good, I guess?
I had some good runs last night with mine.
I missed TQ by .06, but I had the quickest lap in qualifying and both mains.
It was a little tail happy early in the evening. Between the 2 mains, I changed the camber so that it is -2 front and rear.
This helped a lot with the handling and allowed me to be more consistent.
I ended up 2nd overall. Missed the overall win by 3 seconds.
you also seem to have a run now! I wish you the best to get this last 3 seconds!
I also thought about increasing the camber again for the last main, but I was so busy running 17,5 t in parallel, so I have to wait for the next race.
BR,
Matthias
#1100
Here some good message,
for all those who are not limited to TCS rules:
3-Racing restocked the gear diffs for the M06.
I already placed my order for my spare car.
These have been out of stock for a while now,
guess they will be sold out rather quick again...
BR,
Matthias
BR,
Matthias
#1101
True drivers drive rwd.
#1102
As I was asked via PM,
I made up a setup sheet for my last race.
This was the one I made my best lap of the weekend. Most of the setup is completely R or Pro, just some small changes, which I had before converting the shocks and axles to R-spec.
The lower shock position is also from th R-kit, forgot to make a note in the sheet. (anyway we need a setup-sheet for the R) Tamiya, please...
BR,
Matthias
#1104
Where did you order the gear diff? I would like to try one.
I have the ball diff now but i run it so tight & it works well but it bothers me
#1105
I have been searching & i cannot find the bearing size for the gear box.
#1106
http://os.3racing.hk/products.php?products_key=5321
Bearings for the gear diff are 1510.
The rest of the gearbox is 2 times 850, 2 times 1150.
BR,
Matthias
#1109
I bought an M-05 ball diff for mine but I haven't installed it yet.
I'm beginning to wonder if it was a waste of money since the car runs so well with the stock gear diff in it.
But when the gear diff came out, I knew that this was my choice for my races.
I wouldn´t have the time to change the diff in my M06 without missing a run in between. As you are even more busy than me on a race day, I guess you understand that.
The gear diff is so nice for me, as it makes my Mini reliable and a fun car. Put the battery in, and off you go. What I also like a lot are the blades on the outdrives. 3-Racing did a good job on this part...
As mine is run in in the meantime, I´m thinking of going to a thicker oil like 2000cst, at least for our grippy carpet track. That will give even more drive out of the corners, I guess. And this is hardly to realize (consistent over time) with the stock gear diff. But you can have good results with the stock gear diff in the beginning with the AW grease, like it is recommended in the manual. But it will get weaker over time.
Br,
Matthias
