Team Associated TC6 Thread >
Like Tree20Likes
Old 12-20-2010, 06:22 PM
  #1126
Buckaroo's Avatar
Originally Posted by Chris Furman
Here in the USA.. Stock spec racing with 17.5 racing is getting very popular. You have set your timing to what ever you'd like on the motor. But the ESC has NO Boost, NO advanced timing on the ESCs. So we are running crazy FDR numbers like 3.5-3.9... so in this car.. we have to go to a 90-94 spur with larger pinions.
Smaller spur/pinion combos work well, too, to achieve the same FDRs. Not always necessary to "Go Bigger". The car will work better, too, with less rotating mass in the primary drive.
Buckaroo is offline
Old 12-20-2010, 07:39 PM
  #1127
damage's Avatar
Default Hard or Soft plastic
Hello,
Can anyone confirm if the arms, f/r hubs, steering blocks are the hard or soft plastic. The manual part #'s are for soft, but the parts in my kit feel like they are the harder plastic.
Thanks.
damage is offline
Old 12-20-2010, 08:01 PM
  #1128
tqcookie's Avatar
Warren, they are hard plastic. I love my car. Can't wait to come run with you guys again.
tqcookie is offline
Old 12-20-2010, 08:22 PM
  #1129
STLNLST's Avatar
Trader Rating: 32 (100%+)
So is anyone running 64P with the car? I found it a bit strange that the TC5 had to run 48P because of gears being stripped. Were any issues resloved for the TC6?
STLNLST is offline
Old 12-20-2010, 09:37 PM
  #1130
tqcookie's Avatar
I've run nothing but 64p gears on both my TC5 and TC6. Not sure what the issue would be.
tqcookie is offline
Old 12-20-2010, 09:45 PM
  #1131
STLNLST's Avatar
Everyone around here only runs 48P. They said they keep stripping spur gears with 64P in the TC5.
STLNLST is offline
Old 12-21-2010, 03:23 AM
  #1132
hey, useing 68dp with modified and 17,5 stock.
no problems at all
im useing 103 / 41 for Stock (cause we have a fix max gearing of 5.0)
and 103/22 modified for most indoor tracks this is good.
greetings
thilo-alexander is offline
Old 12-21-2010, 04:02 AM
  #1133
They are doing something wrong, 48p is more durable but 64p works just fine. My local club as a good mix of people running 48p and 64p.
Scooter79rs is offline
Old 12-21-2010, 05:20 AM
  #1134
STLNLST's Avatar
no problems at all
greetings
Thank you both for your input. The racers we have here are A-main finishers at major events so that's what puzzles me about 64 vs 48. I'll have my 64P ready to go.
STLNLST is offline
Old 12-21-2010, 05:59 AM
  #1135
JamesReilly's Avatar
Trader Rating: 59 (100%+)
They were using 48 pitch when they made motor mounts that moved the motor in. The orginial TC5 had the motor moved out by a ton. Most of the guys that did this mod didnt tie the motor mount back to the layshaft mount properly causing the gears to strip.
Un-modified TC5's had no issues.
JamesReilly is offline
Old 12-21-2010, 06:02 AM
  #1136
Trader Rating: 3 (80%+)
James beat me to it.
So it sounds like everyone in enjoying their time on the track with the new car.
"The Bob" did an awesome job on this one!
Josh Hohnstein is offline
Old 12-21-2010, 06:08 AM
  #1137
I'm very very sneaky, sir. LOL :P
Old 12-21-2010, 06:48 AM
  #1138
RC MARKET's Avatar
some parts released !
RC MARKET is offline
Old 12-21-2010, 07:45 AM
  #1139
Big Features's Avatar
Indeed he did! Very impressive!
Big Features is offline
Old 12-21-2010, 08:32 AM
  #1140
Rick Hohwart's Avatar
He did a great job and we want to keep it up to date with constant improvements. if anyone has any option parts suggestions, please let me know.
Rick Hohwart is offline
