Team Associated TC6 Thread >
Like Tree20Likes
Old 05-24-2018 | 12:51 AM
  #10381
Thank you. I'll order one from rcmart. There are no 6.0 chassis I can find .So this is good news.
gravediggerNZ is offline
Old 05-24-2018 | 01:22 AM
  #10382
first time I drove this car on carpet it was dialed on minipin tyres. I've gone back to foam tyres and I can't drive to save my self on it . I'm pretty useless at setup. All I've changed is tyres.
Old 05-24-2018 | 01:29 AM
  #10383
Be6
based on your sig it looks like your in NZ? Where do you race? I also drive a TC6. Race at North harbour, Auckland. We run foam tires on astro. Its a pretty unique combination. Im still working on set up but had it going really well at last club day
Be6 is offline
Old 05-24-2018 | 02:46 AM
  #10384
fathead's Avatar
If you are on rcracer.co.nz forum you could jump on and ask us about setup there, would get more sensible answers for our racing conditions/rules I would think.
Be6 likes this.
fathead is offline
Old 05-27-2018 | 08:57 PM
  #10385
cheers guys in Invercargill. I can't tell what is left and right side for c hubs.there is no markings.I'm thinking high hole to the front? And rcracernzcan be pretty dead at times
Old 05-27-2018 | 08:59 PM
  #10386
I've had my old hpi sprint2 driving well .this car I'm going to have to go back to kit setup I think.yes I'm in NZ .Invercargill
Old 05-27-2018 | 11:59 PM
  #10387
Default Front chubs.
Low hole to the front is it? There is no markings for left and right
Old 05-28-2018 | 12:35 AM
  #10388
fathead's Avatar
Yes low hole to the front
fathead is offline
Old 05-29-2018 | 12:47 AM
  #10389
and the different degrees? Just don't mix them up or ya stuffed?
Old 05-29-2018 | 12:53 AM
  #10390
fathead's Avatar
I think standard would be 4deg blocks which is probably what you have, the optional ones are definitely marked, yes stay with same caster on each side otherwise the car will do weird things.
fathead is offline
Old 05-29-2018 | 02:16 AM
  #10391
ok thanks for that. I actual had my caster hubs on the wrong side.it appears even the steering knuckles may be on backwards to.now these are marked L and R.is this from looking at the front of the car. Or like I'm sitting in a real car left and right side?
Old 05-29-2018 | 02:21 AM
  #10392
fathead's Avatar
Yes like you are sitting in the car
fathead is offline
Old 05-29-2018 | 03:10 AM
  #10393
gigaplex's Avatar
Are you sure they're not marked?
gigaplex is offline
Old 05-29-2018 | 10:02 AM
  #10394
jpx's Avatar
jpx
hi guys .using a TC6 forindoor carpet. rear of chassis is getting thin. wil the 6.1 worlds chassis fit please
TC6.1wc chassis will definitely fit the TC6
upgraded my TC6 to TC6.1wc some years ago.
A big change to the chassis was made with the TC6.2 which somebody also allready mentioned.
jpx is offline
Old 05-29-2018 | 04:10 PM
  #10395
fathead's Avatar
Pity it's not a 6.2, I have that chassis on file and have cut 1 out before.
fathead is offline
