Team Associated TC6 Thread >
Like Tree20Likes
Old 12-28-2012, 12:32 AM
  #8446
kewdawg's Avatar
Originally Posted by bmannokc
Nice servo mount! Definitely interested.
kewdawg is offline
Old 12-28-2012, 12:33 AM
  #8447
I would definitely take one! Excellent design!
Vostok 7 is offline
Old 12-28-2012, 04:10 AM
  #8448
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up
Kwikvdub is offline
Old 12-28-2012, 11:11 AM
  #8449
Terra Rover's Avatar
Very Interested
Terra Rover is offline
Old 12-28-2012, 11:25 AM
  #8450
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Rick I know you and I have the same reflex chasis anyway this new arm you made would work for me? If so bring one tomorrow and ill pay you there at the track.
Mr.juarez is offline
Old 12-28-2012, 01:30 PM
  #8451
rclife66's Avatar
Default Spec-r swingshafts for Yokomo BD5
Hi Guys. I presently have a TC6. Anyone know if the Spec-R swingshafts (ecs) for the yokomo BD5 will fit the TC6? Or is it the TC6.1 only? Please, somebody help me out here.
rclife66 is offline
Old 12-28-2012, 06:07 PM
  #8452
TeamGoodwrench's Avatar
Default TC6.1 graphite chassis plate prep ?
Hi --
I've been building pan cars for 20 years. Every one of them we always sand and then CA all edges of graphite parts.
In the TC6.1 manual, I don't see any mention of any chassis prep. Are you guys doing anything with it ? Or just take it out of the bag and start bolting stuff to it ?
Thanks !
TeamGoodwrench is offline
Old 12-28-2012, 08:36 PM
  #8453
Originally Posted by TeamGoodwrench
Hi --
Thanks !
I emailed AE about this and they said
"Sanding and gluing the carbon parts on your car will prevent the carbon fiber from splintering and it will get rid of the sharp edges too. I would recommend doing it but, it is not needed."
I hope this helps.
Old 12-28-2012, 09:04 PM
  #8454
Hi guys
Ive had my tc6.1 for a little while and loving it.
I recently ordered a avid rc tc6.1 bearing kit. I found that the wheel bearings do not fit in my knuckles or rear hubs. The supplied bearings are simply to wide compared to standard and the center of the bearing is to thin for the end half of the uni to go thru all the way.
I have contacted avid will see what they say.
Any one else had this problem?
In the picture u an see the bearing on top (AVID RC) bottom os standard bearing.
AleD123 is offline
Old 12-28-2012, 09:41 PM
  #8455
CristianTabush's Avatar
It seems as you have a TC6 and not a TC6.1. The tc6 uses 6x10x3 bearings ( the ones that fit in your image) and the tc6.1 uses 5x10x4.
CristianTabush is offline
Old 12-28-2012, 09:47 PM
  #8456
Hey
The car has the tc6.1 upgrades but this is the first time i have changed te bearings . Is that that the unis are tc6? How can i make these fit
Thankyou
The car has .1 roll bars .1 front knuckles .1 c hubs .1 front and rear arms .1 rear hubs
Ill just buy some 6x10x3 seems to be the easiest thing to do right now
thankyou
AleD123 is offline
Old 12-28-2012, 11:36 PM
  #8457
YoDog's Avatar
Trader Rating: 28 (100%+)
This mount is only for the stock chassis. At this point, I only have the prototype on my 6.1 for testing this weekend... Weather permitting. It looks like there is a fair amount of interest here so I will try to get a few more prototypes done next week then work on the production pieces shortly after.
YoDog is offline
Old 12-28-2012, 11:43 PM
  #8458
YoDog's Avatar
Hi --
Thanks !
This technique comes primarily from carpet racing and is typically the norm with pan car manufacturers as they are usually run by avid racers but it is always a good idea to dress the edges of the carbon for several reasons.
It's not quite as important to pavement racers to do this but many still do as a part of their build process, myself included.
YoDog is offline
Old 12-29-2012, 12:11 AM
  #8459
KC10Chief's Avatar
I didn't do anything to the edges of my chassis on my car and I'm racing on carpet. I wasn't aware that people did this to their chassis until after I had put the car together. Didn't feel like taking it apart just for that. I have a new chassis coming from Reflex Racing. I'll CA the edges when I get it and then do my old one as well. But I've been racing it all winter and while I'm pretty good about staying off the rails and away from other cars, I've still had a few hard hits. No damage at all.
KC10Chief is offline
Old 12-29-2012, 12:26 AM
  #8460
YoDog's Avatar
The bonding really helps to prevent splintering and catching the carpet which is bad for both the car and carpet. It just a good preventative action. It's also nice to have the edges nice and smooth as a fine detail.
YoDog is offline
