Team Associated TC6 Thread
#4471
Thanks, it is a well done and full of setups tips for everyone, maybe you should put this as a separate post if it does not exist yet.
I am trying to get my son to understand all the in and out of setups so that he can look after his car a bit more himself now and give me a break
#4472
tom do you suggest getting a full ss screw kit or the ae one for the entire car?
http://www.amainhobbies.com/product_...-TC6-Screw-Set
http://www.amainhobbies.com/product_...less-Screw-Kit
is it even worth it trying to put ti screws all around or where neccesay or just go with ss?
#4473
#4475
I use Tony Screwz, no problems. Use them on all my cars
#4476
The parts that are supplied make the car good right out of the box. But the following are what I suggest once you get the car up and running:
#31286 Ball stud washer - To achieve most setups and can be used for arm spacing.
#4617 Bulkhead shims - To replace plastic clip spacers.
#31558 6 deg caster block - To achieve some setups.
#1401 Turnbuckles - To use camber link in the shock tower setups.
#31262 Silver anti roll bar set - To achieve some setups.
To race non boosted stock classes you will probably also need a smaller spur gear.
#4478
I only use 2 steel screws on the whole car...... the ones threading into the motor
#4479
Just to clarify, you mean I can use the part below to replace the 31198 arm mount shims on both the front and rear bulkheads, correct?
#4481
There are socket head cap screws available in 2.5mm and I would suggest replacing the button head screws with these as they use a 2mm hex instead of the stock 1.5mm hex. Mine came loose and even lost one during the RROC. It created a ton of confusion until I found that it was missing the next day. My RCScrewz kit had the cap heads in it from another car and haven't had a problem since, no thread locker needed.
Any suggestions as how i could fix this would be very welcome
#4482
Trader Rating: 27 (100%+)
new to the car, experienced driver anything thing i should be aware of when looking my car over(used)?
#4484
I dont think anyone has had this problem as worse as mine. Saturday, i bought my car, brought it home and started installing my spur gear. Tried to pull the shaft out. Screw 1 on the right side came out with ease. The second one, i managed to round off my hex wrench, so i tried the ball side. Worse to my luck, it snapped, jammed and rounded out the screw. Even worse to my luck, i dont have a dremel. The previous user (The guy i bought it off didnt use it) Put Threadlock in every screw making it extremely hard to remove any screw. It is now tuesday, and i am still trying to figure out a way to get this out.
The best way to remove pesky screws is a screw extractor and some heat. You should be able to find a screw extractor kit at a good tool store. The extractor is based on a reverse thread head which bites into the damaged screw and then twists it out.
#4485
