Team Associated TC6 Thread >
Like Tree20Likes
Old 08-09-2011, 10:34 AM
  #3481
The Evicerator
Originally Posted by jag88
2-mid for the front shock locaton ... would that be 2 on the tower and a drilled hole between 1 and 2 hole on the arm ?
Thanks.
Jag88,
You are correct! I filled the existing holes with a 2 part epoxy and once that cured, I made a hole between them.
If you don't want to deal with that, a silver spring in the outside hole in the arm with 2.5-5 wt lighter oil in the shock should be pretty close.
Incidentally, I noticed that I made a slight typo on the setup sheet...but I think most people will be able to figure it out:
On front camber I intended -1.5 ... not - 0.15! Sorry!
Steve Weiss is offline
Old 08-09-2011, 05:17 PM
  #3482
Trader Rating: 20 (100%+)
Are there any big differences between the TC5 and the TC6? Are most of the parts interchangeable? Thanks
R.Fenstermacher is offline
Old 08-09-2011, 05:24 PM
  #3483
Verndog's Avatar
Trader Rating: 16 (100%+)
Yes, weight, lower COG, narrower chassis, lipo friendly, more adjustability on the TC6. Parts are same from arms out + diff, driveshafts and belts. Chassis, top deck, steering, towers are all different. The TC5 is good, the TC6 is better.
Verndog is offline
Old 08-09-2011, 05:44 PM
  #3484
Trader Rating: 23 (100%+)
If you watch this http://www.youtube.com/watch?v=k6MyM...&feature=feedf he goes over most of the differences..
Rotax125 is offline
Old 08-10-2011, 05:05 AM
  #3485
S_fender's Avatar
Originally Posted by Rick Hohwart
This is correct:
7A 2B Fast
8A 2B Fast
7C 1B Slow
8C 1B Slow
7B 2B Medium
Rick,
Thank you for the fast answer.
Sébastien.
S_fender is offline
Old 08-10-2011, 12:46 PM
  #3486
Suspended
Trader Rating: 86 (100%+)
thinking of getting dial a grip but not sure which pack to get
would 4 pack block 0 and 4 pack block 2 enough?
littlealex is offline
Old 08-10-2011, 01:29 PM
  #3487
Verndog's Avatar
Yes it would as long as you plan to run 1 of the staggered block setups that some are running now. What setup do you plan to run?
Verndog is offline
Old 08-10-2011, 01:35 PM
  #3488
Thanks!
Old 08-10-2011, 01:38 PM
  #3489
justchris's Avatar
Please could some one post the order #
for the upgraded thrust bolt nut as iv'e now stripped
2 many,many thanks.
justchris is offline
Old 08-10-2011, 02:32 PM
  #3490
Verndog's Avatar
2 many,many thanks.
ASC6575
http://www3.towerhobbies.com/cgi-bin...?&I=LX2869&P=7
Verndog is offline
Old 08-10-2011, 07:50 PM
  #3491
Bobert Ross's Avatar
[QUOTE=Steve Weiss;9502417]Jag88,
What are the advantages of doing this? What does it improve ans/or take away?
Also on the setup sheet for the piston setup, what does this mean
3x1.15, 10mm OD
I guess the 3x1.15 is you have all 3 holes the same size ( you dont like the RSD piston hole design?)
..but still confused about the 10 mm OD.
Thanks.
Bobert Ross is offline
Old 08-10-2011, 11:50 PM
  #3492
[QUOTE=Bobert Ross;9509800]
OD usually means "out side diameter"
Rotax125 is offline
Old 08-11-2011, 02:29 AM
  #3493
Big Features's Avatar
I posted a new TC6 setup sheet from Steve Weiss. This is from our local track WCRC which is pretty high grip and sticky. It is an unusual surface so the setup might not suit everyone but it should translate to other high grip tracks.
Steve Weiss TC6
Scuba Steve runs of AE now?!?! Dialed!!
Big Features is offline
Old 08-11-2011, 08:58 AM
  #3494
The Evicerator
Jag88,
3x1.15, 10mm OD
Thanks.
Regarding the shock location on the arm, I felt like the inside position on the arm felt easier/more consistant to drive, yet felt like it pushed in the middle and coming out of the corner... the outside hole in the front arm felt more aggressive but a bit inconsistant in the middle/coming out of the corner, so I decided to try a hole in between... which I feel was easy to drive but still retained consistant steering throughout the entry, middle, and exit of the corner.
Regarding the piston questions:
Yes, that means 3 holes that are the same size, 1.15 mm and "10 mm OD" refers to the outside diameter of the piston which I sanded down from the stock 10.08 mm to 10.00 mm.
I tried the 1,1,1.5 piston and it wasn't bad... but I felt like maybe it had too little low speed pack as it felt like the car stayed dumped over in the corner too long for my liking... I will probably go back and revisit them at some point in the near future as I think there's still a lot of potential to be found just in shock setup... but for the time being, I felt more comfortable with the shock setup from the posted setup.
[QUOTE=Rotax125;9510518]
You are correct sir!
Yep!
Made the switch about a month ago! Car keeps getting better and better every outing!
Old 08-11-2011, 09:46 AM
  #3495
jag88's Avatar
Steve, I noticed you moved the steering post to the 1 position and moved the bell crank back to the 'C' postion. Why, and is this unique to the high bite that you run on ?
Thanks.
jag88 is offline
