Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-05-2025 | 06:02 PM
  #12301
I always have used, almost slicks, Gravity Spec USGT tires handy. Sometimes worn out tires work better, so i save all my winter carpet tires for summer asphalt racing.
Poor_Boy and glennhl like this.
MylesB is offline
Old 05-06-2025 | 08:10 PM
  #12302
Originally Posted by STLNLST
I’m rockin’ one set. I will scuff them in on Friday in practice and set aside for qualifying the next day. The rest of Friday’s practice with be with tires I already have.
Thanks for the info. See you next week.
STLNLST likes this.
belewis01 is offline
Old 05-06-2025 | 09:16 PM
  #12303
Sorry, i missed the part you need to buy tires at the track. Good luck at 1Up.
MylesB is offline
Old 05-10-2025 | 08:20 AM
  #12304
In USGT (1) set of tires is all you need for 30 runs
Juan Aveytia is offline
Old 05-10-2025 | 06:40 PM
  #12305
busman's Avatar
if you want to be slower, Yes
busman is offline
Old 05-11-2025 | 08:51 AM
  #12306
so what’s your take on how long they are good for?
racenut123 is offline
Old 05-11-2025 | 06:57 PM
  #12307
STLNLST's Avatar
I’m curious to hear this answer as well……
STLNLST is offline
Old 05-11-2025 | 08:02 PM
  #12308
busman's Avatar
one raceday! Go ahead ask me how I know
busman is offline
Old 05-11-2025 | 08:18 PM
  #12309
busman's Avatar
So as a disclaimer, apparently if where you race is sprayed the tire wear drops dramatically, Here in Seattle at our SeaTac track we’ve quite good traction, our RD refuses to spray, so as a result we are compelled to buy a fresh set each and every weekend.
So feel lucky and go buy some lotto tickets, and please by all means send some compassion our way.
So you may get 30 runs, But! Here not !
busman is offline
Old 05-11-2025 | 08:24 PM
  #12310
skypilot's Avatar
we were only getting one maybe two race days depending on track temp. 6-10 runs usually.
we have a very abrasive track and don't spray.
we also quit using the gravity tire and have switched to the sweep d spec threaded, longer wear and better traction
busman and Raman like this.
skypilot is offline
Old 05-11-2025 | 10:02 PM
  #12311
STLNLST's Avatar
Guess we are spoiled out here as I get 20-25 runs on a set. Some of these runs are 5 min quals and 8min mains. Practice is always race conditions so 5min and a lap.
busman and glennhl like this.
STLNLST is offline
Old 05-12-2025 | 01:22 AM
  #12312
TonysScrews's Avatar
Do you run the Gravity gray belted USGT tires on carpet where you are at? If so, I find that these are horrible on asphalt compared to the regular non-belted Gravity USGT tires.
busman, Poor_Boy and glennhl like this.
TonysScrews is offline
Old 05-12-2025 | 07:36 PM
  #12313
Yes, Gravity belted gray rim tires. They spray where we race. I don't find them loose, if that's when you mean by horrible. I also have a couple of sets of non-bleted spec tires. I will try them too in a couple of weeks and let you know.
MylesB is offline
Old 05-12-2025 | 07:51 PM
  #12314
STLNLST's Avatar
spray or not the gray rims are considerably slow lap time wise compared to the non-belter
STLNLST is offline
Old 05-13-2025 | 07:19 AM
  #12315
Raman's Avatar
The new version of the ride USGT tyres do not balloon or swell up, last a lot longer on asphalt, and are very good. To date I have not seen a belted version and I don’t think you would need one.
pirate the release of these we were running to sweep as well because it was lasting longer.
Raman is offline
