USGT
#7651
While I agree that the motor of the month things is something that can get tiring. I also have seen the truth in that some motors are significantly faster than others. One of the thoughts on fixing this problem is in creating spec motor classes. In Ripon there is talk of starting a 13.5T Reedy fixed timing class. You could do something similar with USGT.
Sigh. This comes up every time. The point isn't to make the fast guys slow. It's an attempt to reduce the cost of frequently buying new motors because they're perceived to be faster.
Also, you said that running a faster motor would magnify the issue even more, then said the solution is to run the fastest motor class, mod. It's the slower motors that increase the need for a horsepower advantage.
spec motor, now everyone thinks they need a special battery, spec battery now everyone thinks they new a special esc, spec esc, now everyone thinks they need a special charger, spec charger,now everyone thinks they need a special radio, spec radio now everyone thinks they need a special chassis, spec chassis, now everyone thinks they need a special body.. Nobody ever thinks they need to learn how to drive, everyone's a winner.....
#7652
Again, nothing would change:
#7653
Looking around, soo many have everything mentioned above, gotta pay to play, then update again
After I have all that top of the line stuff, I should look to hire a driver, or at least attend a driving school.
#7654
I have run in the VTA/USGT/F1 national points series since its inception. Their rules are very specific about motors for their classes. My concern about events run under the Can Am rules and referred to as "USGT" and "VTA" may not qualify for national points due to this difference.
If you aren't Rob, Kevin, or Hanulec, feel free to keep your conjecture to yourself.
If I was to chiose to partisipate in the usvta southern nationals with a 25.5 motor in my usgt car I would still be eligible for points right ?
So if the entire field is handout motors I dont see how that would change anything (since the speed is nearly identical to current usgt speeds) in terms of points ... Usvta nation knows theirs a problem with the 21.5 game which is why the 25.5 idea is even being batted around ...
And yes motor matters when your running near the front of the pack ... If I had been abke to purchase a 2nd new motor (first green mootor failed tech ) I would have been 2-3 seconds faster than I was with brand X motor I ended up running putting me 2nd/3rd on the grid vs the 7th i was at ... .1 a lap makes a difference after 33 laps .... Handouts would have possibly got me closer to a W for me and one other that was behind me that didn't have green motors ...
#7656
IF you're getting smoked in a drag race down the straightaway, not due to entry onto, but flat out drag race, then you will need to have top drawer stuff, motor, battery, charger, discharger...and will need to keep up on it.
As mentioned earlier, maybe if too much horsepower is available to begin with, all you would need is skill to make use of it as the electronics wars are easily met with average motor, charger... too much motor, remember.
Then get your tire and replacement parts sponsor or a platinum credit card and you're all set.
#7657
No feelings here ... So I dont know why points would be withheld or not given based on motor ...
Theories and Can-Am rules do not factor in at all in the given example.
#7660
if you run USGT, its 21.5 unless its changed by the USVTA....and since its not...there you go.
Now IMO, Can-am GT isnt USGT, so I dont think points are allowed....cause if thats the case Spec GT at Vegas should be able to get points too?...but they dont
also, I caught that Robk...LOL, you got me....so whats the body weight?...95g?....and driver figures ?
#7664
Somebody needs to ask if the Can/Am 21.5 motor is on the ROAR list of approved motors for USGT. I would but I kind of promised that I would refrain from participating in the Can/Am cluster frock so they wouldn't pick on my choice of timing system or my little race track..
#7665
R/C Tech Elite Member
