Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 12-13-2016 | 12:54 AM
  #5896
Dan's Avatar
Dan
Bruce, that TP compound is actually Mighty Gripper yellow compound. It works good for norcal. I've heard the rumors of it eating tires but honestly, as long as you wipe down the tires after your run with Tuning Haus tire cleaner or Protoform body cleaner (same stuff), it will keep the tires feeling fresh and soft. Norcal has really inconsistent traction also during the day.
Dan is offline
Old 12-13-2016 | 01:52 PM
  #5897
Looking at the USVTA rules about USGT... There's no lower weight limit for FWD cars. Has anyone gone bonkers and built a 750g (pulling a number out of the air..) car to make a fool out of the AWD cars?
Nerobro is offline
Old 12-13-2016 | 02:01 PM
  #5898
howardcano's Avatar
I believe there are several guys here that have tried; I think patorz31 was one of them. I'm not sure how light they went.
But, a big disadvantage in running a car that light is a high CG, so on a track with any reasonable traction the cornering speed is limited by traction rolling.
howardcano is offline
Old 12-13-2016 | 02:06 PM
  #5899
it will take some real work to keep the CG down.... The other side is "what downforce you DO get, is that much more effective" And you're accelerating a whole heck of a lot less weight out of corners.
Nerobro is offline
Old 12-13-2016 | 02:36 PM
  #5900
JustWill75's Avatar
#40 W.S. Reedy TC7.1
JustWill75 is offline
Old 12-13-2016 | 04:37 PM
  #5901
robk's Avatar
If you can do it more power to you. We took away the weight limit in an attempt to get people to run FWD. Few if any ever have tried.
robk is offline
Old 12-13-2016 | 04:48 PM
  #5902
Thanks for the reply. Car was really good in the mains, but I wasn't sure if it was because I changed traction compound or because they resprayed. What ever it was, it was a big improvement over the qualifiers.
I guess next time I'll have to stick with one compound, at least for the 1st main.
Bruce
Bam - 90 posts -
belewis01 is offline
Old 12-13-2016 | 05:24 PM
  #5903
patorz31's Avatar
My fwd is down to 1058g. If the track is open its real competitive. If it's tight with a lot of slow turns, it gets killed coming out of the hole. Now Ivan (Bone crusher on here) is running a fwd now and does well with it, but the guy can wheel anything.
patorz31 is offline
Old 12-13-2016 | 09:10 PM
  #5904
The seed is sewn. I need to bug the FF guys now. I'm currently thinking of how to get the CG stupid low, and weight on the front tires.
If I make you need to add the weight rule back, I will have done my job properly.
Nerobro is offline
Old 12-14-2016 | 05:56 PM
  #5905
RotorTruck's Avatar
Originally Posted by belewis01
What is a good traction compound for these spec tires on parking lot asphalt? Track is sprayed 2 - 3 times during the day with traction compound, I believe it's VHT.
Just started on road again after a loooong break running USGT, now 2 races in. 1st race used Paragon Black. Works OK, smells awful for days and days. Yesterday started with the Paragon, then tried a brand new Team Powers compound - labeled as "Shock Oil" - which was really good, but costs $25 a can, and I'm told it eats tires.
So, rather than bumming around the pits and asking to "borrow" different types of traction compounds, can the racers here on RCTech suggest my next compound?
Bruce
Mix the Paragon Black Can with WD-40, 50/50 mix, it takes the edge off the smell and has monster grip. Or just switch to SXT 3.0.
RotorTruck is offline
Old 12-15-2016 | 05:11 AM
  #5906
What wheels do you guys recommend for the spec ride tire and foams?
I do not like the abs plastic wheels on gravity premounts. I prefer more durable nylon
like most traditional race wheels. Abs plastic and hard click track don't mix well with me. Lol.
Antimullet is offline
Old 12-15-2016 | 05:18 AM
  #5907
Rodarbal's Avatar
Personally, I liked these Solaris wheels:
Rodarbal is offline
Old 12-15-2016 | 05:28 AM
  #5908
Thanks RJ!
Old 12-15-2016 | 06:13 AM
  #5909
I like the 24mm wheels from Kyosho or Jaco.
mooby64 is offline
Old 12-15-2016 | 06:28 AM
  #5910
SpeedySST's Avatar
I run my USGT tires on Speedmind wheels. I also have a set of Exotek but cant tell the difference between them and the Speedmind.
SpeedySST is offline
