Losi XXX-S
Re: toe end set up
Originally posted by wwjd
in the rc car action touring car book it has a set up for carpet
on brian kinwald touring car, it says it has 2 degree toe end in the back. does it have 1 degree per side or is there 2 degree toe end blocks please help
thanks mike
thanks mike
Per a Matt Francis setup, I run 1-1/2 degrees on my carpet car for sportsman stock class racing.
lack of interest
Well touring has taken a slump at the local track so i decided to race oval and sell the losi, at least untill the new car arrives. Yeah right not unless i want to give it away as a no reserve for $50.00 on Ebay. Looks like everyone is selling in anticipation. Unless the I can sell it for closer to what it's worth it looks like my 5 yr old is getting a slightly used xxxs g+ for xmas
I run the same setup everywhere!
Setup
Thanks!
ZoomZoom
hi,
has anybody got a good base setup for a carpet track with rubber tires?
track i will be running is medium tight. mod motor
i wud rather a setup without a one way but im not really too fussed.
thanks
thanks
go to the Losi site and they have some rubber tire setups. SC-27 to be exact. If you've looked at those then i have a setup thats not on the Losi site that Todd Hodge sent me. If you want the setup PM me and ill send it to you.
Hex adaptors
Hey guys I'm going to race indoors for the first time ever and I have a question about the hex adaptors. Presently I purchased Jaco 28mm foam tires and when I put them on the car they hit the bottom og the shock mount when I turn the tires.
These are zero offset tires. Should I get 2mm offset tires or can I use another companies hex adpators. I read that the TC3 will work. Is this true. What is everyone else doing
meche
meche
The TC3 adaptors are the ticket. They are about 50% thicker than the Losi units. Come in both plastic and graphite. You want the graphite ones.
With the stock XXX-S CVDs, you need to use low profile locknuts to get the nylon to effectively lock onto the CVD threads. This is how I do it. Otherwise, the compatible CVDs off the TC3 are a fraction longer than the XXX-s units. Some people take this step.
Bill you got mail
Originally posted by JohnMatrix
Bill you got mail
Bill you got mail
Limiters?
Hi,
I know this probobly sounds like a stupid question but im trying to copy Paul Lemiuex's setup from the 2003 US indoor championships. He uses .090 limiters on the outside of his front shocks and .060 on the outside of the rear. What does this mean, where do you put these limiters and what do you use as limiters?
Also how would you go about lowering the rear block .060 to lower roll centre?
and finally when he says .060 does that mean inches? im from the UK so i work in metric.
any help would be much appreciated!
thanks
thanks
Losi XXX-S G+ out of the box
Hi all,
I was wondering if anyone has a setup sheet per the kit instructions. I tried transposing the info but may have made a mistake or two. The reason I aks is that I would expect the setup to be for asphalt but I ran it on Ozite Carpet the other night with 45 shore tires up front and 42 in the rear and it worked fairly well right out of the box. I ran 30w oil with Purple front springs and silver rears, 1 degree camber, 1 degree toe-in front, ride height 5mm and a droop of 3mm front 5mm rear.
rinkrat go to losi site they have all the setup sheets for you and blank ones as well
setup sheets losi g+
