Losi XXX-S
Originally posted by kevin2
for 2mm of droop on a ride height gauge about how many limiters do you want in the shock?
Good news is that after you play with the inside shock limiters a few times, it becomes pretty obvious as to what to use for your various setups. FYI...Low roll center setups tend to use about half the inner spacers of a high roll center setup.
You also have about 2+ full turns of the ball cups on the shock shafts to play with for fine tuning. So if you get into the right zone with the spacers, you should be able to adjust the droop from 2-5mm without having to open the shocks change the spacers
If you cut the LOSA5050 shock spacers into a "C" shape (using a Dremel or plastic snippers), it makes the process of inserting and removing them WAAAAAAAAAAAY EASIER.
Originally posted by JohnMatrix
If it was not for this thread I would be driving backwards still.
he, he...
You can vindicate yourself this Saturday.
thats what the B in B main stands for. LOL
i thought it ment balistic?? or is that for the A-main only
Thank you...
James. That is all I needed.
Mounting a Novak GT7
Just wondering how those of you running a GT7 in your xxxs mount the capacitor. There's not enough room to mount it on the side of the ESC, so where do you put it?
I'm torn between buying the GT7 or the LRP QC2.
Kind of hard to see because of the black case, but there's plenty of room to mount the capacitor on the side. Just mount the switch on top.
R/C Tech Elite Member
I mount it behind the motor, I have the capacitor mounted on one end and the switch on the other with no problems. I have also had the same setup in front of the motor.
STLNFRST are you Jeff M. from Sac. area? C.J. and I met you at Reedy this year.
Charles
Charles
Just took some new pics of my sedan with the Tamiya shocks.
Hey Randy,
I heard you picked up an Xray, how do you like it?
Nick
Nick
Hey Randy,
Nick
Hey Randy,
Nick
Originally posted by XXX-S Bill
For a definitive answer to your question, you would need to indicate which low/mid/high inner pivot supports (low, mid or high) and how you mounted the front (0F/4F or 2F) and rear (0R/4R or 2R) outer blocks for both ends of the car.
I think I got it right with the droop but when I set the ride height I have to crank down the shock collar all the way and it still is at 4.5mm so I moved the ball cups a little but then it wuz set at 2mm of droop in the front and 3 in the back.
