Like Tree2Likes
Losi XXX-S
Old 04-04-2004, 03:42 AM
  #9691
Xtant3150c's Avatar
Thanks for the info NVisible! I will try this on my car. And also thanks for the tip on the bearings! I know that I need to clean them out anyways so I will try the lighter fluid trick j/k!
Thanks for jkerr0043!
I pulled the motor out and it did'nt feel like their was a bind, but I will probably end up tearing it down and rebuilding it if I need to.
One more thing I have read about cutting every other tooth on the belt? Is this a must do mod to have a smoother running xxx-s?
Mahalo guys for your HELP!
Xtant3150c is offline
Old 04-04-2004, 04:07 AM
  #9692
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
For the bearings, I remove both shields and just spray them out with motor spray, that should remove any grittiness you have. Then just use 2 drops of royal oil per bearing, it'll be enough.
I think the every other tooth is a must do mod, it's free and it'll get you a quicker accelerating car, and your batteries will last longer as well...
Randy Caster is offline
Old 04-04-2004, 04:12 AM
  #9693
Batteries only last longer if you stay on-power, once you lift you are taking life from them...
ZER01 is offline
Old 04-04-2004, 04:22 AM
  #9694
Originally posted by Cardboard
how many degrees of anti-dive do the low-roll pivot blocks add?
That depends on how much you shim the inner block and what postion you mount the outer moute in the bulkhead w/via shims.......
ZER01 is offline
Old 04-04-2004, 06:13 AM
  #9695
Oasis's Avatar
Trader Rating: 38 (100%+)
On removing every other tooth on the belt are you doing this on the black belt also ? And how is this belt "trick" holding up in mod,I run a 10x2 most of the time and dont really like changing belts..
Oasis is offline
Old 04-04-2004, 06:58 AM
  #9696
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Batteries WILL last longer if they don't have to work as hard ie: the drivetrain is more efficient, the motor is more effficient, the driver (throttle) is more efficient...
RKeasler is online now
Old 04-04-2004, 08:36 AM
  #9697
NVisible's Avatar
Default Turnbuckles
I really dislike adjusting my turnbuckles on my xxx-s. Seems when i try to adjust they always pop out, or i have to use needle nose pliers on one end as i try to adjust them, just a pain in the arse. Im using the ones that came with the RTR kit, would a lunsford set with the rpm ends help this at all? maybe im doing something wrong. I even put lube on them like it said in Drakes article in RC Nitro, but same thing
NVisible is offline
Old 04-04-2004, 08:41 AM
  #9698
Default Rebuilding Diffs?
how tight should the diffs be after rebuilding them?
SPC Racing is offline
Old 04-04-2004, 08:46 AM
  #9699
mike_Webb's Avatar
Default Re: Turnbuckles
The Problem is that 1..you did not lube the end of the turnbuckle and 2. make sure the turnbuckle ends are not at the end of the ballcup. I went to the offroad ball cups on my XXXS and I also dremeled off a little bit off the end of all the turnbuckles. I have never had a problem with the buckle coming out of the ballcup and poping off when I adjust it.
mike_Webb is offline
Old 04-04-2004, 09:10 AM
  #9700
NVisible's Avatar
well, i did lube the ends of the turnbuckle, but maybe i used the wrong stuff? what did you use?
Noticed that the turnbuckles on my MFE are very easy to adjust, so maybe ill go the same route
NVisible is offline
Old 04-04-2004, 09:14 AM
  #9701
mike_Webb's Avatar
I used Assocaited Black Grease.... I think the big change to make is going to the longer Ballcups.
In the front and the rear of my car the Ballcups go all the way to the turnbuckle adjuster on the shaft. in the rear that gives me 2 degrees of neg. camber (I never run that much) and in the Front on the steering when the ball cups are against the adjuster that gives me 2 degrees of Toe-Out (I never run that much) so it is good. For Camber in the front if they go all the way to the adjuster it gave me 4 degrees of neg camber.. so that is the only spot where the ballcup is further away from the adjuster nut.
Old 04-04-2004, 09:16 AM
  #9702
NVisible's Avatar
great, thanks alot!
NVisible is offline
Old 04-04-2004, 10:06 AM
  #9703
Trader Rating: 16 (100%+)
I rub the turnbuckle against wax before installing. The wax can be an old candle or the bar of wax used on my skis.
Still Bill is offline
Old 04-04-2004, 05:56 PM
  #9704
racer-oZ's Avatar
XXX-S Bill, how long have you been waxing your turbuckle? couldn't resist that one!
racer-oZ
racer-oZ is offline
Old 04-04-2004, 06:35 PM
  #9705
pro3racer's Avatar
nice one
pro3racer is offline
