Losi XXX-S
#7801
Originally posted by Super Steve
ok guys, i got the car, but i have no idea of how this car's set up works, specially the A arm mount
the rear says 0R and 4R upside down.
Can anyone shed some light?
Pics (notice my bashed up foams)
#7802
Originally posted by Trevor
Hi,
Does anyone know where I can get a stainless steel screw kit for the XXXS?
Trevor
Hi,
Trevor
#7804
Trader Rating: 32 (100%+)
If you run the stock one use two of the gold rings it will center better....I use a Kimbrough one and its fine.
#7806
most electric tcs including the XXX-S are 190mm.
foam works best for tc carpet racing but some places still have a rubber class. check http://www.teamlosi.com/setups/index.htm for a starting setup, but your setup changes with every track.
#7807
First time on track with XXX-S
Well after dinking around with this car for 6 weeks, I finally ran it on a real carpet track; this is also my first time running any RC car on a track. My driving naturally was terrible. I am lucky I only broke one part in the suspension.
I finally took the advice of someone here on the forum and trimmed the throttle so the car went about 1/2 speed with the trigger pulled alll the way. With this setup I was actually able to do a lap or two without hitting the wall. I can see, I got a lot of practice ahead of me.
I had just a few questions.
1. If my primary concern is control and I am running on a small carpet track with foam tires and stock motor
any advice you can give me on the setup of the car. Does setup even matter, if I am doing slow laps trying to learn to drive the car? (assuming no settings are way out of stock spec)
2. What adjustments can I make to my controller(besides the one I already made cutting down the top speed); that will make this car easier to drive.
3. Are graphite parts stronger than stock XXX-S parts? When I bust something should replace it with graphite part? I assume Aluminum is less likely to break but more likely to bend and throw off the stearing geometry.
Thanks in advance
Thanks in advance
#7808
don't worry about set-up too much until you can make quick laps without the assistance of a turn marshall. look on losi's site for set ups and go with one that most closely matches your track conditions. I like the andrew gray setup. just set up the car and don't play around with it too much. once you get better at driving, only then will you'll notice the difference in subtle changes.
I don't suggest dailing out throttle on your controller, but instead learn to use throttle control with your finger. this will be cruicle in the future(carring speed) as you become more competitive.
graphite parts are alot more brittle than standard plastic parts(expecially in the winter). just go with the standard parts, cost is less and and durabillity is much higher.
hope this helps. rob
#7809
#7810
actually, wheelbases differ and is adjuastable 190mm and 200mm is the width of the cars. most electric sedans being 190mm and nitros being 200mm
#7811
Actually from my experience the Losi Graphite parts are more durable..... Does anyone else feel the same....
Here's why I think so...... When a standard composite part breaks you can see that the plastic is more porus (air pockets in the plastics) which takes away from it's durability... When you break a Graphite part you don't see as much of this..... I broke tons f standard composite parts and have actually broken very few Graphite pieces...
#7812
Hi,
Trevor
Hi,
Trevor
www.rcscrewz.com
#7813
i have to agree, although the plastic ones bend or flex a little (in theory absorbing a little bump), i find that graphite parts are less prone to breakage with light taps.
#7814
Originally posted by audiaudi
Why not titanium?? I have some, PM me... :cheap:
#7815
Hi,
Do all of you use the grub screw to adjust the droop or is there a better way of doing this? The plastic bumper's flex is causing the droop to be inconsistent. Any ways to cure this problem is much appreciated.
