Like Tree2Likes
Losi XXX-S
Old 10-02-2003, 03:37 PM
  #7216
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by losi jon
Randman-i use the ballstuds your talking about and i like them very much. the only thing you have to do is ream the bushing out that goes through the top of the front castor blocks very slightly. then your good to go!
Cool, is the fitment of the ball end/ball cup as good as stock?
Randy Caster is offline
Old 10-02-2003, 04:39 PM
  #7217
black-knight's Avatar
Originally posted by highwayman
The G+ stock set-up has a bit more rear rotation to my liking, i changed to the standard rear hubs with 1 degree toe.
The springs are ok, but now im using green fronts and red rears, (pretty much Todd Hodge's socal set-up, with a few variations), also the car comes with 30wt oil... but that's pretty much your call, depending on how you want the car to react.
thanks for all the info guys... it's good to get some feedback, and ideas.
black-knight is offline
Old 10-02-2003, 04:49 PM
  #7218
akrcracer's Avatar
I have always felt 3 mm was slightly bigger in dia than 4-40..
akrcracer is offline
Old 10-02-2003, 05:27 PM
  #7219
it does use a little larger diameter thread.
Old 10-02-2003, 06:25 PM
  #7220
losi jon's Avatar
Randman-yes,me and my friend both have them and like the fit of them on the ballcups,they feel real good.
losi jon is offline
Old 10-02-2003, 08:18 PM
  #7221
Cool, I'll pick up a set to try, MUCH cheaper than the ones from Losi.
Old 10-02-2003, 08:56 PM
  #7222
how are you likeing the losi blacknight?
Losi_runner is offline
Old 10-03-2003, 06:45 AM
  #7223
rayhuang's Avatar
Hey guys,
Can you enlighten me again on the use of front anti-dive on the XXXs. What it does and why you would use it? I went through dozens of posts for Todd's explanation on here and TT and came up empty handed.
Thanks,
Ray
rayhuang is offline
Old 10-03-2003, 07:25 AM
  #7224
dpaton's Avatar
Well, to be honest, the XXX-S can't have front anti-dive, because that would require that the front of the hingepin be lower than the back. The best we can hope for is a flat hinge pin, which will reduce the tendency of nose the car to drop during braking and tight cornering.
Basically, it makes cornering more agressive and front braking more effective at the expense of handling bumps.
-dave
dpaton is offline
Old 10-03-2003, 07:45 AM
  #7225
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by ChadK
Or you could just buy Lunsford TI srews and ball studs, also the Lunsford quick tunes for the shocks are a great part.
Chad
Chad, how are things out your way?
STLNLST is offline
Old 10-03-2003, 07:53 AM
  #7226
Dpaton, sure you can. Just use some shims under the rear mounts for the front arms. By shimming this way you can achieve a lower front pin height than the rear.
Doug Gaut is offline
Old 10-03-2003, 08:21 AM
  #7227
The Evicerator
Uh, there are plenty of ways of getting anti-dive on the XXX-S. You can either add shims to the rear mounts like Doug Gout recommended, or you can simply use a different front suspension arm mount block. The roll center you are running dictates which mout and what position you must run it in...
On high roll center, you can run the 4F block in the lower bulkhead holes to attain anti-dive.
On Losi low roll center, you can run the 0F block in the lower bulkhead holes to attain anti-dive.
Hope this clears up some confusion.
Steve Weiss is online now
  #7228
dpaton's Avatar
I was trying to speak to folks who were working with the stock setup. Front anti-dive is indeed possible, but getting those washers in without total disassembly of the front end is a real pain IMHO...
-dave
dpaton is offline
Old 10-03-2003, 08:36 AM
  #7229
rayhuang's Avatar
Okay-getting there on the knowledge!!!
So car steers more aggressively in or out with anti-dive?
In other words-is it turning in or squaring up better?Thank you all in advance,
Ray
rayhuang is offline
Old 10-03-2003, 08:55 AM
  #7230
dpaton's Avatar
Ray
The car will stay flatter in the corner, which should equate to squaring up better, since it's less non-square throughout the corner. Because of the mechanics, you may percieve that it's turning in more agressively too. For me, the car has more 'snap' coming out of a tight corner. (I run 0 degrees of kickup)
-dave
dpaton is offline
