Like Tree2Likes
Losi XXX-S
Old 12-05-2002, 03:48 PM
  #4531
pimpedaccord's Avatar
Trader Rating: 25 (100%+)
Thanks guys. I knew it was a solid diff, but I didn't know it came with it. I'll be getting my G+ tomorrow, anybody have any good carpet setups?
pimpedaccord is offline
Old 12-05-2002, 04:00 PM
  #4532
Yes the PRP towers are nice. I have been running with my front camber links in the center top holes for about a month now. With this location you can gain more mid cornering traction and exit traction. With a tight diff, it really makes the car aggressive on corner exit and sweepers but aids in corner entry too. Give it a try!
Doug Gaut is offline
Old 12-05-2002, 06:36 PM
  #4533
StephenSobottka's Avatar
Guys I am assembling a xxx-s. It is my first time with this kit though. I am assembling the belt tensioner assembly and the pulley on the tensioner squeezes the spur gear. I did rotate it around clockwise as stated but it is still touching the spur gear and rubbing. Is it supposed to do this??????? or where did i go wrong?
StephenSobottka is offline
Old 12-05-2002, 06:55 PM
  #4534
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
On the spool pads that come wit the G+...will they be a seperate item that a person could use on the current losi? Also any otehr parts needed to make it a spool?
Jeff
Jeff Werner is online now
Old 12-05-2002, 07:34 PM
  #4535
i fixed my own prob guys, bearing wasnt snapped fully into place.
Old 12-06-2002, 09:58 AM
  #4536
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Does the G+ come with steering bearings?
Also, does anyone know where I can find the Blue Alumi Servo Mounts for the XXX-S? Besides ordering from Europe.
Thanks.
ChristopherKee is offline
Old 12-06-2002, 10:08 AM
  #4537
HarshGuy's Avatar
Yes it comes with steering bearrings ...you can get the red trinity servo mounts from Speedworld Raceway 916-783-8864
HarshGuy is offline
Old 12-06-2002, 10:13 AM
  #4538
Thanks... But I was looking for the BLUE servo mounts
Old 12-06-2002, 01:11 PM
  #4539
dg8one's Avatar
christopherkee
if find those blue servo mounts and bell crank oder one for me too and i'll just pay you back.
nelly
see yah sat
dg8one is offline
Old 12-06-2002, 02:04 PM
  #4540
No way... I'm gonna be the only one with them
JK... I found the Bell crank, Motor Clamp and Drag Link already... Just need the Servo Mount and I will be True Blue... (cuz it makes you faster)
Old 12-06-2002, 03:26 PM
  #4541
Blakesrc's Avatar
Trader Rating: 26 (100%+)
Default Bumpsteer?
Anyone notice a large amount of bumpsteer(towout) on our cars? I just installed speedtech bellcranks and never looked when the stock bellcranks were on the car. I used 2 small losi washers to correct it, should I have?
Blake
Blakesrc is offline
Old 12-07-2002, 07:44 PM
  #4542
I did the same thing as well. this is the correct way to correct bumpsteer.
Old 12-07-2002, 08:08 PM
  #4543
Where did you put the ball stud washer's, and how many?
Action-RC.com is offline
Old 12-07-2002, 10:08 PM
  #4544
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
what exactly is bump steer? how do you notice it, and what does it do to the car?
Cain is offline
Old 12-07-2002, 11:49 PM
  #4545
Blakesrc's Avatar
Bumpsteer is when you compress the front suspension and the front wheels either go from being straight to tow in or tow out. I installed 2 of the gold losi ball stud washers under the ball stud on the bellcranks to correct it. It might need a little bit more, like a thin armature spacer.
Blake
Blakesrc is offline
