Like Tree2Likes
Losi XXX-S
Old 08-12-2002, 10:14 AM
  #3421
shrekair's Avatar
Trader Rating: 9 (91%+)
same motor, just everyone is a little different and i didnt wanna confuse companys. that nd peak labels the carrera as "super touring" and it is supposidly set for a touring car but i dont think it makes a difference. i've been running an 11x1 in my sedan and a 12x2 in my truck
shrekair is offline
Old 08-12-2002, 11:04 AM
  #3422
OBY
OBY's Avatar
Originally posted by LouisB
Thanks OBY, my set-up is not anywhere close to stock so that may have been why it didn't go so well in the wet. In damp conditions (pit treaded worked best) my car was going really well, I only made 1 mistake in the final and it was handling better than any other car at the track BUT down the straight everyone was cruising past me This is really odd b/c i had an 11x3 Orion chrome and they had mostly 12 turn motors
It was geared according to the manual which seems to be about right for short tracks and was quite hot at the end, something must be wrong so I'm going to get a new motor and leave the 11x3 in my Pro-10. I was thinking a Core 12x1 High speed or as there are no motor restrictions at my club a 11x2, which 12x1 do u have, high speed or high torque and how does it go?
yeah i used to run mine way different from stock and it was terrible!!!
i ran a 12x1 Core high torque had to gear down a few teeth from what i normally run though to pull it out from the water. no wheelspin though, plenty of grip.
for damp (greasy conditions) try either the CS22's or the sorex 20r's, these are best in those conditions.
after testing i've found sorex to give good grip, but not last very long. take off's have better grip and last ages!
OBY is offline
Old 08-12-2002, 11:44 AM
  #3423
TeamPRP's Avatar
Default shock towers
Originally posted by proudwinner
Sounds great Shrekair, I'll keep that race inmind. Man I sure would like to see a company make a XXX-S rear carbon fiber shock tower with some lower shock mounting holes on the tower.
Hey proudwinner,
Yep, we're doing shock towers. I don't have a release date but the info will be posted on the Team PRP site as soon as we are closer to production.
Thanks!
Ben, Team PRP
http://home.attbi.com/~teamprp
TeamPRP is offline
Old 08-12-2002, 12:45 PM
  #3424
LouisB's Avatar
OBY, i normally use Take Off tyres, sometimes Sorex (I've also found they wear quickly) recently I've tried Orion/hotbodies tyres, they start off with massive grip, then wear quickly then start to work well again (a bit like Michelin F1 tyres) I've also experimented with Gandini/fast tires foams (I think the company's now been bought by Ernie) Have u seen the add for ING tyres? do u know what they're like?
To everyone, what's the minimum number of turns I can use for a 5 min race and 2400's
LouisB is offline
Old 08-12-2002, 12:50 PM
  #3425
Evil_S10's Avatar
Team PRP,
Try to inform us on the release of the shock towers, I personally know that I will want to get these. Especially with lower shock holes.
Evil_S10 is offline
Old 08-12-2002, 05:34 PM
  #3426
Hi,
Will it be similar to this...
ongbenghui is offline
Old 08-12-2002, 05:39 PM
  #3427
Default Re: shock towers
Originally posted by TeamPRP
Hey proudwinner,
Thanks!
Ben, Team PRP
GREAT! I'll be one of the first to buy one when they are available.
ZER01 is offline
Old 08-12-2002, 06:02 PM
  #3428
Fire's Avatar
i want one for the front and one for the rear!!!
Fire is offline
Old 08-13-2002, 02:44 AM
  #3429
OBY
OBY's Avatar
i've seen the ING tyres advertised..what they are like i haven't a clue!
i used to run a 13t with 2400's. a 14t is a really safe bet though, just watch you dont up the timing too much, most of the race is made in the corners, straight line speed isnt that important.
OBY is offline
Old 08-13-2002, 03:23 AM
  #3430
LouisB's Avatar
I've been using a 11x3 chrome touring for a while with 2400s and have never dumped. I think it had a problem last time because it was sparking badly, go hot and was quite slow. I skimmed it after the race and it had the same problem, i'll check the timing+ brush hoods and see if something's wrong.
LouisB is offline
Old 08-13-2002, 07:19 AM
  #3431
maybe you have the timing retarded. I hardly see people dump these dasy because of the really good batts out there.
teamAE is offline
  #3432
shrekair's Avatar
ongbenghui - the shock towers are of that idea. they wont be exactly from what i've been told, i should see the design soon.
proud winner - clear out your PM message box. (make sure to dump all your sent messages)
shrekair is offline
Old 08-13-2002, 07:24 AM
  #3433
LouisB's Avatar
I think I've fixed the problem, I took the motor apart and found that one of the brush hoods was dented from what must have been a nasty crash so I bent it back (probably when someone was going down the back straight, hopped over the hose, and smacked me in the side) I cut the comm again, cleaned the brushes and now it works fine but I still might get a Core
TeamAE I think the timing's OK
LouisB is offline
Old 08-13-2002, 07:25 AM
  #3434
shrekair's Avatar
i'm really liking the new "top" motors. power band has been ultra smooth.
when ur fingers cant type, thank god for the edit feasture.....CRAP
shrekair is offline
Old 08-13-2002, 08:50 AM
  #3435
Fire's Avatar
how about trinity's P94? it's comm design sounds pretty ideal, is it as good as it is advertised in reality?
Fire is offline
