Losi XXX-S
#2521
coming in one hole on the front shocks has always given me a more smoother turn in. When I want the car to be a bit more responsive I came out on the tower. This might be different for other racers. There's nothing better than testing so try a couple of different things and see what works best for you.
#2523
R/C Tech Founder
I am fairly sure that no change has been made to the kit design. You'll still need to make the modification.
#2525
i already have the bearings in the bellcrank but i will try some different ballends and studs. i will try all your sugestions and see how i go with my settup.
#2526
Registered User
my steering came with considerable slop and if you remember back to the street weapon days, there were these little rubberbands you put around the diff bearings to seal them or something but you never did, put two around each tie-rod in the steering and basicly takes it out of the picture.
#2527
all the kits had the "stops" on the stearing knuckle....the aded stops are for faomn tires, and you glue a .030 washer tothe knuckle......
#2528
What is the purpose for the different set of holes, where you can control the position, for the Front and Rear Diff Cover? Are they just for the use of the high roll center mount and low center mount?
#2529
R/C Tech Founder
Yup, that's exactly it. The other set allows you to run the low roll center option.
#2530
so you only need the stops when running foam tires? why not with rubber?
#2532
Here's my 2 girls all ready for the Speedworld cup. I'll get some inside shots after I go through the innards and rebuild'm. http://www.arroyoc.com/thegirls
#2533
Thanks for the reply.
I stripped one of the top hole in the front diff cover. I would like to know can I use the 4 degree Pivot holder with high center mount and the lower hole to get two degree kickup, like default.
#2534
Wow seems like this thread isn't always at the top like it used to be. Everyone must be out enjoying their cars Anyway, I've come back to the XXX-S after a little stint with a FTTC3. Just missed the way this car handles....... I'm going to start racing mod so the Losi seemed like a better choice over the TC3 as far as my driving is concerned.
David Joor- Could you give me some pointers with gearing for mod considering you run with foams on carpet? Do you take tire wear into account as the day goes on? I know for stock racing I always figure out my roll-out which gives me a good ratio based on tire size but with modified it seems like a whole different ball game.
Any help anybody can offer on this subject would be much appreciated.
#2535
Honestly on a local level, I find the gearing that works best in practice and maybe gear up one tooth in the 3rd round or main. The tires don't wear that fast so find what is best in practice. My track is small so I run a 128/24 on a 10dbl with a 76foot straight and 61mm tires. I run a 23 on a 9dbl and a 25 on a 11dbl, just 1 tooth difference. The Losi is a great mod car, that is it's bread and butter.
