Losi XXX-S
#2311
Originally posted by BLAZN420
sanitair,
Ive always run 4 deg. on the car......with 0 kick......try that or maybe try some kick.....are U running the batts. up front?????
sanitair,
#2312
ttr..try ron rosettis setup from losis web site..i love it....
#2313
mad_cats: thanks for the info i thought the composite ones will fit because they look almost exactly the same, even the lengths. might as well go for the losi aluminum ones.
#2314
marvi
The only differance I can plain see between the two is the ball Dia. that fits into the Diff.
#2315
Anyone use a Kimbrough Spur Gear to check ride height? It is exactly 5mm. Just reading R/C car with Kinwalds stock asphalt setup.10mm droop sounded a little extreme. Does anyone else run this much? I'm set at 3/5 and 0 kickup
#2316
MDM3-The 10mm droop is measured from the bottom of the chassis to the bottom of the tire. The article says he measures with the tires on the car.
#2317
Originally posted by R_Andersen
Guys, I'm running a setup with black front shocks and purple rears, 80 weight oil all around and red and orange pistons. I run on a tight ozite carpet track with purple foams up front and pink foams in the rear. I have a problem with the car pushing on corner exit when under power and the right front wheel chatters real bad. Any advice on what causes the chatter would be appreciated.
#2318
springs
anybody using the associated springs on the xxx? i was telling a newbie at the track about how cool ae was for selling a kit with all their springs in it, someone else stated the ae springs would work on the new xxx-s.
http://www2.towerhobbies.com/cgi-bin...1&I=LXAZU0&P=7
check out the paper in the photo, "#3988 for TC3 and xxx-S"
anybody tried this, do they work?
#2319
Chad. Thanks Missed that important detail.
#2320
Just checking. Does the new chassic make any differents. It is very Expensive man. Thinking of buying one.
#2321
The Chassis by itself is an ounce lighter. The whole conversion kit... I dunno how much lighter it is. But Graphite is more rigid then plastic, so you're parts are stronger and you definitely have less flex.
Jits
Jits
#2322
Hyperformance
I run asc springs on my XXX-S. I used the lower spring cups off a TC3 and everything fits nice. I dont remember for sure but I might have run my hobby knife around the top of the spring to scrape off the excess paint so they fit Losi threaded collars. I know I had to do that with one car I ran asc springs on.
#2323
Hype:
ASC and the Yok springs will fit the XXX-S threaded shocks - no problemo, no scraping.
YJ
YJ
#2324
Droop and Preload questions
I've been working on gettting the ride height and droop set properly on my XXX-S and I had a few questions. I have the droop set at 3 in the front and 5 in the rear. I'm also running 4mm ride height front and rear. I have the short threaded shocks in front and the standard length threaded shocks in the rear and I'm running uncut proline foam tires. I'm also running the 1.0" springs front and rear.
The problem is that I had to run very little spring preload to get the proper ride height. Now when I pick the car up, the shocks do not extend fully to the droop screws. When I extend the suspension fully to the max droop, the spring is not under any preload. There is actually about a 1/8" gap from the top of the spring to the adjuster nut on the shocks. It seems that since the springs can not extend far enough to ever make contact with the droop scres, that the droop setting is meaningless.
If anyone could tell me if this is normal or what I need to do to correct it, it would be appreciated. I am assuming you would still want some amount of spring preload at full droop.
Thanks,
Rob
Thanks,
Rob
#2325
One more question also. Do you need different front carriers to get 4 degrees of caster or are the stock carriers the 4 degree ones? If they aren't, what's the part number for the 4 degree carriers?
Thanks again,
Rob
Thanks again,
Rob
