Speed Passion Cirtix Stock CLUB ESC
#751
#754
Is 3 volts per cell a little low? Used the set up last weekend, works very well, only thing is one of my 4 month old turnigy lipos won't take a charge. During my weekend of racing at no time did I hit lvc. I'm aware the battery may have just decided to throw in the towel, gowever, all the other systems I have are set with a higher lvc of 3.4 volts per cell. A 6 volt lipo cut off just seems to low am I correct?
#756
#762
check out here
http://www.tqracing.com/sensor.htm
the best in the business - soft and flexible, perfect for you F1
#764
#765
No..not really, to be honest, I have whole box of sensor cable but I am sure 50% of them are not from Speed Passion...they just all works, at least, that is a good thing.....
BTW...Speed Passion does sells 180mm and 250mm sensor cable....I used the 250mm for my 1/8th buggy and 180mm for my 1/8th Serpent on road...if 250mm is not long enough, you must be running some kinda electric funny car bigger then 1/8th scale....
http://www.speedpassion.net/us/produ...p=162801&c=OPT
http://www.speedpassion.net/us/produ...p=162803&c=OPT
