Speed Passion Cirtix Stock CLUB ESC
#346
I did the exact same thing.. to warm up the tires and soften up the tub chassis
#347
we all ran this speedo at ETS in Heemstede we were all running gearing of 3.5 or lower , motors were warm and speedos didnt temp out , we had 32 dergees C weather that weekend too
I destroyed two over the weekend , 1 was as soon as it was plugged in , it smoked
Then in Quali i was just setting off and it went full throttle and then stopped
These were all preproduction models and over the weekend i think there was only 10 or 15 broken , this isnt bad saying there was 200 there
i havn't had any problems since with lack of power , i run one in my T3 sometines in out "stock" class and one in my Tc-02 buggy with a 10.5 SPv3 motor and no problems
#348
mark did you keep your chassis out in the sun too? Because if so then I guess that can confirm that as the reason
#350
I would think that if you have an esc that has internal temp of 72 deg it would take a much longer time for it to reach 203 deg than an esc with an internal temp of 120 deg.
Since our esc could have been hot from the sun right before the race, couldnt you say that the esc had very little time before it reached thermal vs one that had a lower starting point?
#351
With the Cirtix I am getting no more than 116-125degF motor temps and 110DegF esc after each 5min race. When im practicing for lets say more than 10 min, I can get my motor 160+ and esc at 120.
In the case of your normal temps being so low I guess sitting in the sun could have raised it some but it wouldn't be a dramatic difference.
#352
I ran the club spec ESC w\ a 17.5 in RCGT this past weekend. Track was a 160ft straight (if you didnt lift for the kink at the end) and Saturday practice outdoor temps were nearing 100F. ESC ran flawless in these conditions.
Sunday's race temps were down into the upper 80's, and again no issues with the ESC.
Jimmy
Jimmy
#354
I ran the same race on Sat both my cars never thermal shut down. I have the thermal turned off on the esc my sons car has a heatsink and fan his car came off the track at 112deg, My car has a heatsink no fan came off at 136.
Both cars are Cyclones geared for a 3.53 fdr.
My Cyclone is geared at 88/54 with a 18t center pulley.
My sons Cyclone is geared at 84/58 with a 16t center pulley.
#355
I'm running 88/55 in the TC (18T) that's the one that thermaled at 2 minutes left. The GT never had an issue, it's an S and I'm running 80/56.
#356
Do you have the thermal protect turned on??????
If you watch the Video both our cars ran flawless.
Which car was yours????
Mine are the the Black,Green and White one and the Black,Yellow,Red and White one.
If i can lend you a hand let me know but maybe the fans and heatsinks on the motor helped out on the hot day.
#357
What I do to heat up my tires is I went to Target and bought a tube of tennis balls for a couple of bucks and put my tires in the tube and set that out in the sun until the race before mine. Gets the tires heated up but not the rest of the car. YMMV
#358
Interesting that one tooth difference would do that.
#359
Ha, just looked at the results. I was the blue/white one chasing you. Was in 5th when it thermaled, looks like you got around me about 6 laps in. The car has plenty of speed on the front straight. I still don't see how charlie is gearing to 3.3 and not thermaling. One thing I noticed is the parking lot at Sonrise goes up hill on the straight. I ordered a decent temp gun, so I can get some readings off the can. I'll drop down to a 54 if needed.
#360
Super Moderator
