Speed Passion Cirtix Stock CLUB ESC
#181
#182
Non Timing Motor Adjustment.
today timing is no cheating.
because you can buy verry low cost motor with timing adjustment on it.
In Fact Motor with no Timing Adjustment will provoke us to do cheat.
and make us to have suspicion on some one to cheat.
Without Timing Advance on motor, will also push us to buy other brand,
only to get same Windings(Turn) with Different Fixed Timing build in.
and that's is Expensive, i Think it's no Sportsman if it's expensive.
#183
there are several types of racing around the world that have controlled specs for what you can and can not have. If sportsman rules say no timing, then you need to have a motor with no timing in it, if you feel the need to cheat then thats what your going to do no matter what class or what the rules are. this system is very inexpensive, if as a sportman you feel the need to have more expensive stuff, then run another class. not really seeing the issue.
#185
Why using timingless Motor
#192
My son and I had our first ever TC race yesterday running these systems.
I must say i am very impressed with the performance as this system was running comparable lap times as the open 17.5 class. Very close racing.
I would like to thank Charlie B for his setup advice. We placed 3rd and 6th in the main out of a 10 car field.
We had a great first time out my son is now hooked and looking forward to running the CIRTIX SUMMER SPEC SERIES.
#193
Best $70 I have spent on this hobby to date
#195
