Tamiya FF03
#1006
Izzy, info on this page
http://www.rctech.net/forum/californ...aceway-13.html
#1007
#1008
Hey guys!
I am going to run this car starting in the Fall.
Anyone have a good starting carpet setup? I would like it with Tamiya tires if I can get it.
Please post on the thread for others or send me a PM!
Thanks!
Thanks!
#1009
Does anyone know if the TRF201 diff Joints work in this car?
because the actual diff gear is the same and all.
I'm thinking it could only be incompatible is if the outdrive diameter is different and or the outdrives are too long - which case it could be cut down...
#1010
Who else has built the non Pro FF03 kit?
I'm wondering which tires these are in the kit.
I have no way of tellin.
I'm hopin we got lucky and they threw in some sticky slicks, B3s anyone?
Gonna hit Tamiya tomorrow in the am and see if someone can tell me, maybe by comparison?
#1011
I'm still in Toronto with limited internet access but will try to answer and provide additional setup information (even pics?) when I return this weekend.
#1012
#1013
Tamiya also makes the Hop Up Part # 54233 which are aluminum and come with the plastic dog bone "blades" and plastic diff nut carrier.
#1014
For those who are attending the TCS nationals, here's the setup sheet from today's qualifiers. It's a bit of a departure from the stock setup and will require arm flipping and some work to change to it. Also, longer camber and steering link turn buckles would be recommended.
Thanks to kentech and petitrc for the setup sheet as an editable pdf file.
*edit* I found a mistake on the shock mount position on the rear arms. The attached image should reflect this correction.
#1016
I measure from the top of the axle to the setup board
#1018
If a picture is worth a thousand words...here's a bunch
Hi guys, I'm back from my trip and hopefully was able to answer questions on here or via PM. I've attached several pictures of the car untouched from last weekend's TCS race. The only discrepencies between the condition of the car in these pictures and how it was run in the second main event was that the transponder was removed so that a fellow competitor could use his transponder, as well as installation of a different motor, complete with ham-fisted motor soldering job by Timmy haha. Basically, the car was loaned out for the third main
Hopefully this will shed some light on additional questions that may arise. You'll notice the use of different ball studs (instead of the hex headed versions which are 1mm taller) for the camber links. Also, I had to trim a little bit of the gear cover to clear the inner right front ball cup (it was rubbing a little). Other than that, if you look carefully, you'll see most of which hop ups were used on this car. Also, fast lap from the mains was 15.717 seconds...yikes!
#1020
Hiya DB. I'm not sure I can quantify how much the "tuning" helped. Several weeks prior to the nationals, I was cleaning my car on a Sunday morning and noticed my 416 sitting on one of the benches. One thing lead to another and after a bunch of measuring and checking out geometry, I decided to try to replicate my 416 setup on the FF3. The next weekend, I immediately ran more consitent "fast" laps than my fastest laps run with a narrow setup (faster...more consistent...yeah, I'll take that). From that point, I was sort of committed to work on that setup path (it would have been a pain to convert everything back). During the next few weeks, it got to the point of tuning with a lap counter. Some changes would make the car feel faster, but laptimes were slower. Other changes would make the car harder to drive, but lap times were better. So, to be honest, I used the lap counter as a tuning aid. I took notes of A and B comparisons and did a lot of collaborative setup testing with Don and Lee Passehl. I believe we were running identical setups for the TCS weekend and they were very fast too. As for improvements, I feel that I can use more rip coming out of corners (without loosing any steering) and will eventually work on it.
Last edited by rtypec; 09-05-2010 at 11:09 PM. Reason: Looks like it was fast enough :) Please see the attached image lol
