Hot Bodies TCX
#1336
LOL...didn't see your post Agno.
#1337
#1339
#1340
#1342
#1344
#1345
Thanks for the info everyone much appreciated.
Ran my TCX this past weekend, the car is very good.
very stable throughout the track.
very easy to fix driving errors, cars reacts very quick to steering input.
Build quality is fantastic.
had a little problem with traction rolling so have to work that out but it was only on certain parts of the track.
Not sure if this has been answered but are there any Front Steel dog bones for the front, it's the only thing on the car I find myself checking over and over again.
For anyone running 17.5 Stock Non boosted, I found a gear combo of 100 spur with 52 pinion worked great,
had to take the motor mount brace off to keep the pinion from hitting
using a spur from 100 to 104 is probably the best option.
What surface were you running on?
Rubber or foam?
Cheers
#1346
Are the stock TCX shock shafts pretty smooth or are the titanium shock shafts the way to go? Same goes for the suspension shafts. Just seeing if I should upgrade them now while I am building or wait until I wear out the stock TCX parts.
What about shimming? Was much shimming needed on the suspension shafts or bearing areas?
#1347
#1348
Purple battery tape
Agno helped me find the purple battery tape. I thought I'd share since I'm sure a lot of you will want some of this bling. You have to order it from HK.
http://www.rc-mushroom.com/product_i...ducts_id=14826
#1349
#1350
