Hot Bodies TCX
#721
#725
took it for its first run today, before the rain came down, and with the exception of a little push off power it was by far one of the best cars i have every driven
all i can really say is fan******tastic
#726
I would recommend the Futaba S9551:: http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0661
#727
Have to agree; fantastic, best TC I've driven. Will be waiting to see the TC6 in the flesh first then make a decision about which to get. Until today the TCX wasn't in contention due to annoying HPI spares availability in the UK, but the car is so good I'll put up with that.
#728
Traded?!? Insane! You came out of the deal a winner!
#732
Yes we are able to put the spec-r gear diff on the TCX if you would like to.
These are what you will need,
1. Spec-R gear diff for Tamiya 416x
2. Tamiya 416x front drive pulley
3. HB Cyclone TC front and rear drive belts
4. Tamiya 416x rear drive shafts
*For the rear drive shafts, you can also use our HB universal drive shaft (44mm) with plastic blades w/some dremel work on the drive cups on the gear diff.
I would suggest to start with #1000 diff lube.
Please let me know if you have any questions.
Thank you.
Thank you.
