Hot Bodies TCX
#4442
I use MR additive.
I have a gear diff i can try which is probably what i will try first, but will certainly give some of the other things you mention a go should this not give the desired effect
will let you know how the changes go john
thanks
#4443
I will be at Bedworth for the next Clubmans round on the 8th, down on the 7th for practice. Will see how the setup goes then, may need a small tweek or two but should give you a good base to work from
#4444
#4445
#4446
#4452
Hiro...will that change again as it was meant to be March release date , just getting itchy feet as i need to buy a new car soon as my TCX is a few years old now.
Cheers
Cheers
#4453
I'd like to run a shorty pack in the future and this new TCXX doesn't appear to have anything which will secure a shorty pack in place very well, or allow one to be moved about (to balance the car).
Missed opportunity by Hot Bodies? or maybe they're thinking about selling
a shorty pack chassis for it, at a later date?
#4454
hi all. basicly stoped racing 3 year ago last had a TC and loved it so..
just got my hands on a new tcx and after some help.
i am looking at what set up to run on the front eg spool and driveshafts. what would people recomend been looking at the specR DCJs and the hb one which would be best? i cant stand chatter lol. and is the kit spool anygood?
then other bits to buy for it? gear diff etc am looking to make a bit of a list then order it all up.so anything of use to me would be good. i have searched on hear but therse so much info its crazy.
and finaly has anyone got a set up sheet for low/medium grip outdoor tarmac track,as i seem to have forgoton most things. will be running mainly boosted 13.5. on sorex 32s
thanks for any info
thanks for any info
#4455
thanks for any info
thanks for any info
I run a tcx with Roche spool and tamiya 46mm drive shafts. Tamiya 3 hole shock pistons. 1.5 degree front block and pro4 front arms because there not as brittle as the tcx ones
That's all I find that's needed
