Hot Bodies TCX
Old 07-30-2010, 07:20 AM
  #376
spencehotbodies's Avatar
Default gear diff
Sorry to say I don't have the part numbers, a friend had spares that i am trying.
The gear diff will give you amazing pull from the line, when its up and running its no diffrent to a ball diff.But in finals amazing of the line.
Cheers
Spence
spencehotbodies is offline
Old 07-30-2010, 05:24 PM
  #377
Yes we are able to put the spec-r gear diff on the TCX if you would like to.
These are what you will need,
1. Spec-R gear diff for Tamiya 416x
2. Tamiya 416x front drive pulley
3. HB Cyclone TC front and rear drive belts
4. Tamiya 416x rear drive shafts
*For the rear drive shafts, you can also use our HB universal drive shaft (44mm) with plastic blades w/some dremel work on the drive cups on the gear diff.
I would suggest to start with #1000 diff lube.
Please let me know if you have any questions.
Thank you.
Hi-LowBlow is offline
Old 07-30-2010, 06:07 PM
  #378
Luke Hobson's Avatar
Yep as per hiro says with regards to the gear diff.
I'm waiting until the next shipment of kits now, September... Maybe october
Luke Hobson is offline
Old 07-30-2010, 06:13 PM
  #379
Trader Rating: 32 (100%+)
Hi Hiro,
How about bringing that bad boy to West Coast tomorrow? I would love to see the new car!
ittjv is offline
Old 07-31-2010, 03:20 AM
  #380
bigz's Avatar
Got my TCX at last. Good to know that they have brought back some of the moorespeed goodies like the bumper brace. Still lacking alum bearing holder and shock adjust nuts though.
bigz is offline
Old 07-31-2010, 04:12 AM
  #381
yokemad's Avatar
Diff plastic!
yokemad is offline
Old 07-31-2010, 05:17 AM
  #382
mild seven's Avatar
Trader Rating: 63 (100%+)
Originally Posted by yokemad
Diff plastic!
its composite plastic. never had wear issues in the older cyclones and like others have said here, it feels more consistant compared to the alloy diff.
mild seven is offline
Old 07-31-2010, 06:35 AM
  #383
yokemad's Avatar
Is that why none of the pro drivers using plastic diff?
Although some using complete different car lol
Xray thinks plastic shocks as good as lovely cyclone or tamiya shocks
They both sounds same
yokemad is offline
Old 07-31-2010, 06:41 AM
  #384
Default final gear ratio
if l use there parts what will the final gear ratio be ??
Peter Reardon is offline
Old 07-31-2010, 07:16 AM
  #385
k_bojar's Avatar
Trader Rating: 30 (100%+)
wow...I think we got a HB-hater
If you don't like how the chassis is spec'ed out, then don't buy one
k_bojar is offline
Old 07-31-2010, 07:52 AM
  #386
yokemad's Avatar
What are you on about?
That's not your business to tell people what to buy or not to buy...
I'm looking for a new car and collecting info here !
Chillpills bud and remove that flame!
yokemad is offline
Old 07-31-2010, 08:16 AM
  #387
Thraex's Avatar
The Tamiya diff pulley has 37t, layshaft pulley has 20. So 37/20= 1,85 (instead of original 39/20= 1,95)
Thraex is offline
Old 07-31-2010, 01:29 PM
  #388
Coldn's Avatar
the pro drivers use alloy diff, because its more resistant with motors 3.5
the Plastic outdrivers is resistent, but I beleave the maximum it supports is motor 10.5T.
Coldn is offline
Old 07-31-2010, 02:33 PM
  #389
Yes,the aluminum out drives are more durable. But that doesn't mean the composit one is not durable. You can use the composit one for mod with no problem in fact Hara won the TITC w/composit out drives. He also used 46mm drive shafts at the race.
Thanks,
Old 07-31-2010, 02:47 PM
  #390
mac853's Avatar
Questions??
Thank you.
Pardon, did you mean 416X rear belts, but why did you say also Cyclone TC rear belts as well, they are similar?
About the blades, can not use Tamiya drive shafts, since we want to use Tamiya blades?
And for another question, what could i do if i want to put this geardiff to my Cyclone TC, please?
Best regards
mac853 is offline
