Hot Bodies TCX
Old 08-01-2010, 09:27 PM
  #406
Originally Posted by mac853
But how?
It is 35T?
I just can't remember what i used (center pulley and belts) at that time as it's way long time ago. If you could find the right pulley and the belts, it is able to try the gear diff with Cyclone TC.
Thanks,
Hi-LowBlow is offline
Old 08-02-2010, 07:56 PM
  #407
For those who (will) have a TCX, an editable setup sheet is available on petitrc.
It seems none is available right now from HB.
HTH
Arn0 is offline
Old 08-03-2010, 07:54 AM
  #408
Airwave's Avatar
Will the DCJ be compatible with the TCX? Can we adapt them?
Airwave is offline
Old 08-03-2010, 07:57 AM
  #409
No, to short in front, u can use them in rear but no point on using them there. U can use pro4 mip cvd as they are 46mm long
tomislav is offline
Old 08-03-2010, 08:07 AM
  #410
Airwave's Avatar
Crap! I was thinking about trying to mount the double articulation on TC driveshafts... They are too short, but with the double articulation...
Who knows... or who can try...
This
on this
Am I a dreamer?
Airwave is offline
Old 08-03-2010, 09:11 AM
  #411
Joven M's Avatar
Never had the privilege of seeing a TCX up close, but does it share a lot of parts with the TC?
Joven M is offline
Old 08-03-2010, 10:52 AM
  #412
Some u can use but it's new car, most important parts are new ones like front spool, center pulley, rear diff, belts, dogbones, front and rear shock towers, bulkheads, motor mount, etc. -it's like was with pro4 to cyclone swich
tomislav is offline
Old 08-03-2010, 10:59 AM
  #413
This
on this
Am I a dreamer?
U can't do that,
you can use axle, mip or standard, with new dog bone but forget about DCJ's,
I have old but great pro4 mip and square titanium dog bones Also asso tc3 dog bone will work there so lot of options in front. U can try composite IRS TC3 mip style dog bones if u can find them
tomislav is offline
Old 08-03-2010, 11:56 AM
  #414
ali_g's Avatar
Originally Posted by tomislav
U can't do that,
composite? isn't very fragile?
ali_g is offline
Old 08-03-2010, 12:39 PM
  #415
no, it's less fragile then alu, if u hit hard alu will bend or brake, composite will stay the same as it's flex capable.
tomislav is offline
Old 08-03-2010, 12:46 PM
  #416
AGNO's Avatar
I used years ago on the HPI PRO 4 the TC3 composite shaft, but they were extremely fragile... It breaks easily pin hole and not have a large steering angle.
AGNO is offline
Old 08-03-2010, 01:06 PM
  #417
i still have them on pro4, but i don't have steering angle that stress out pin hole, always take care of that, with alu or with composite, i don't like when cvd's are stressed at pinhole due to the performance and wearing. I Always try to make setup so that i have more steering without stressing dog bone/axle joint.
tomislav is offline
Old 08-03-2010, 02:41 PM
  #418
AGNO's Avatar
Sorry I expressed myself badly, the amount of steering is the same but the composite shaft have more chatter (at least that's what I noticed).
AGNO is offline
Old 08-03-2010, 03:18 PM
  #419
Airwave's Avatar
Bad luck, DCJ were really the must for cornerspeed...
I just got mine right now... Tomorrow will be an interesting day...
Airwave is offline
Old 08-03-2010, 04:34 PM
  #420
AGNO's Avatar
[QUOTE = Airwave ; 7757281 ] sfortuna, DCJ sono stati veramente il must per cornerspeed ...
Ho appena ricevuto il mio in questo momento ... Domani sarà una giornata interessante ...
[URL = http://img638.imageshack.us/i/img0905ed.jpg/ ] [IMG] http://img638.imageshack.us/img638/3749/img0905ed.th.jpg [/ IMG] [/ URL] [/ QUOTE]
Vorrei : cry: ma non riesce a trovare a disposizione in qualsiasi negozio : flaming :
AGNO is offline
